Results 1 to 10 of 13
- Jul 2009
- 11
April 1st, 2013 10:20 AM #1Hi Guys,
have any of you experienced problems in power steering ?
i had my Alterra checked by my mechanic and he said that there is a problem with some oil seal resulting to the ATF fluid not flowing properly and dripping. He said that a Power steering / Rack and Pinion repair kit would fix it. however, i could not find that said kit for an alterra.
basically the problem is, the ATF fluid is dripping and the steering wheel is really hard to steer. its like there is no power steering at all.
need your inputs guys and how to address the problem.
currently , my alterra is undergoing diagnostics in CASA. the maintenance person in the CASA said, if what my mechanic said is true, they do not replace oil seals but only replace the assembly itself which will cost hundreds of thousands
thanks !
April 1st, 2013 10:34 AM #2
sir kung ganun naman kamahal dalhin mo nalang sa banawe... ang alam ko dyan nasa 2.5k lang yan including the repair kit.... not sure lang at alterra ang ride mo ha... pero i have seen benz, nissan, bmw, honda almost all makes ang models there...
near yan sa dating PCSO... if galing kang quezon ave... mag araneta ave. going to the old pcso office... then turn right sa aurora... kung hindi sa unang kanto sa 2nd na kanto turn right.. makikita mo madaming maliliit na shop dun na gumagawa ng power steering... wag ka matakot at expert sila pag dating sa power steering at rack n pinion....
April 1st, 2013 11:19 AM #3
- Jun 2014
- 1
June 7th, 2014 01:00 AM #5sir Ganidmahn, napa-ayos nyo ba yun rack and pinion ng alterra nyo? saan nyo napagawa?
i have the same problem at ang mahal ng bagong assembly =(
- May 2016
- 2
May 17th, 2016 04:38 PM #6
- May 2016
- 2
May 17th, 2016 04:43 PM #7
- Dec 2009
- 15
June 19th, 2016 03:19 AM #8Sir hows your power steering na? Tama yung direction na tinuturo ni sir Glenn. Kung mahirapan ka hanapin, just go to old banawe first, try to look for Colt Master shop. Nagbebenta sila ng oil seals/repair kits para sa p.s racks. Look for Elmer, he will direct you dun sa sinasabi rin ni Sir Glenn na area ng gawaan. hth
- Sep 2016
- 2
September 21st, 2016 02:59 PM #9
- Jul 2016
- 1,178
September 21st, 2016 08:30 PM #10Sir ilan odo meter nyo nun bumigay ps ng alterra mo? May alterra din kasi ako. Ngayon ko lang nalaman sirain pala power steering ng alterra. 102k odo na yung sakin. Palit na nga ako ps fluid tomorrow takot nako e. Hehe
Sent from my SM-J500G using Tsikot Forums mobile app
