Results 1 to 10 of 10
    Jan 2009
    boss need help ngayon lng kmi ngkaron ng matic kya im not familiar sa maintinance ,ask ko lng san ba maganda magpa change oil automatic tranny ng sportivo kc sa isuzu alabang 11,500 kc bka san kya mura at quality service im sure marami alam mga katsikot jan...
    Sep 2008
    sir just my 2 cents, if you are just doing your regular PMS any suking gasoline station would do. change the ATF and gear oil every 10K km.
    other than the ATF basically it is the same as a manual tranny.
    though I would recommend speedyfix if you would want to have the entire vehicle checked.
    oh, and it would be better to keep the OD (overdrive) on except when on steep uphill or downhill roads.
    ako naman, DIY lang ako ng change oil ng ATF every 3 months pero yung 3-4 liters lang. sabi kasi hindi naman lahat ng oil nadradrain sa A/T, only a part of it. magpapachange oil ako ng buong tranny ke speedyfix pag dumating na yung pina-quote ko sa kanya
    Aug 2008
    Quote Originally Posted by GOTCH*! View Post
    sir anu po ba effect ng hindi pa OFF ng overdrive pag steep uphill or downhill?
    Aug 2008
  6. #6
    e di hihirapin mo makina mo! atleast the at is not obligated to go to the topmost gear--for power when up hill, engine brake naman pag downhill..
    Feb 2009
    Quote Originally Posted by mnny_21 View Post
    mnny,
    if your car did not come with an owner's manual, the most common service interval is 20k miles or two years whichever comes first for regular duty, but for extreme duty like pulling trailer, excessive idling, stop and go traffic, extremely hot/cold climates, delivery service etc, the service interval is somewhat shorter. to reduce pollution, service only when necessary. check with oil compatiblity since wrong atf will definitely ruin your tranny. the universal ones now are dexron III/mercon IV. better yet check the dealer service department so as not to void the warranty. check the fluid regularly. to do this, perform on a generally level surface with the engine at idle, apply the parking brakes, apply the service brakes, shift from park-reverse-d3-d-2,1 at about two second intervals and place back to park, with the engine still idling, pull trans dipstick, wipe, reinsert and check the oil level. this should be between low and full with corresponding trans temperature. just make sure if you topoff, service or change the oil that it is the factory recommended atf
    jick
    Quote Originally Posted by mucho_chinito View Post
    [/b]
    Quote Originally Posted by alwayz_yummy View Post
    yumyum is correct :bwahaha:
    pero most likely mangyayri lang to pag mabilis takbo mo. siguro starting mga 60+ kph.
  9. #9
    pag galit ka sa enginebrake during downhill, dapat marunong ka mag-drifting like takumi!
    hehehe
    Feb 2009
    Quote Originally Posted by s_quilicot View Post
    q,
    the trans has o/d and it means of course it is electronic. the parameters for o/d operation are: the coolant temperature be between 190-240 degrees fahrenheit, throttle opening between 40-80 percent, vehicle speed above 35 mph (sorry, just convert to metric), the engine is not on limp mode and the o/d switch is in the on position. if the cooling system is overcooled, the o/d does not operate since it is one of the parameters that the engine coolant is within the normal operating temperature and not warming up or simulating cold engine operation.
    jick
help:automatic
