Results 1 to 2 of 2
    Oct 2008
    Gud am, pwede ba gamitin ATF dexron III marcon sa Sportivo?
    Feb 2009
    Quote Originally Posted by lemans250 View Post
    lemans250,
    your sportive(isuzu) i believe - apologies for not being familiar with philippine models- should have the same requirements as that of general motors, dexron II or higher. the current ones are even higher than the dexron III/mercon4. check your owner's manual for compatibility to avoid warranty problems. usually the dipstick or the drain plug tells you what fluid it takes.
    jick
ATF dexron III Marcon
