Page 561 of 607 FirstFirst ... 461511551557558559560561562563564565571 ... LastLast
Results 11,201 to 11,220 of 12125
    Jan 2018
    #11201
    Quote Originally Posted by kipper View Post
    Sa mga nagpalit na ng battery, im planning to replace my 2smf to 3smf, kasya lang ba sa lagayan ng battery? Wla need galawin?.. salamat
    Kakapalit ko lang rin ng battery Sir. Motolite Excel 24 2SM, fit naman sa stock battery tray.
    Nov 2015
    #11202
    Quote Originally Posted by Brentt View Post
    You need to remove the battery tray na plastic pang 2sm lang ung kasya. Merong 3sm battery tray plastic na nabibili.
    Thank you boss, wla dun sa binilan ko ng batt tray para sa 3sm, nainip ako :-). nagcut na lang ako dun sa pang 2sm para magkasya 3sm batt
    Nov 2015
    #11203
    Quote Originally Posted by neutral View Post
    Sir ako pinilit ko na rin replace from 2sm to 3sm, pero nagadjust pa ko sa batt tray. Motolite Gold try ko. Pakiramdam ko mas maganda hatak ngayon :-D
    Dec 2008
    #11204
    Isuzu’s New Year’s resolution: BLUE POWER - Motioncars | Motioncars
    6 speed transmission with lock up torque converter, this explains rpm reduction from 1,800 rpm to 1,500 rpm upon reaching the speed of 100 kph at 6th gear. It is also noticeable when lock up mode disengages when engine rpm goes back to 1,800 rpm but still in 6th gear. This happens when there's gradual change in road grade while at 6th gear then engages again when the road levels back. One can try this by setting cruise control at 100 kph and observe rpm as the road grade changes.
    Nov 2017
    #11205
    Quote Originally Posted by Caracter View Post
    Nice read,very informative...proud mux owner here[emoji4] .
    Sent from my Redmi Note 4 using Tsikot Forums mobile app
    Jan 2013
    #11206
    Does the new 6AT still have the grade logic feature? I think I read somewhere na same daw ito sa gamit ng new Fort/Hilux. The old 5AT also cruises at 1800RPM at 100km/h, mas ok nga yan lalong bababa pa. 😄
    Sent from my E6683 using Tsikot Forums mobile app
    Dec 2008
    #11207
    Quote Originally Posted by LancerA174A View Post
    Yes it also has grade logic feature, the lock up only disengages when going up grade at rpm speed of 1,500 to use maximum torque of the engine at the lowest rpm which starts at 1,800 but at higher speed and rpm above 1,800 it remains activated even going a little uphill. This feature is only working when in 6th gear.
    Maybe they used the same transmission pero walang jerking problem ang MU-X hopefully wala kasi very smooth talaga ang shifting.
    Ok rin yung 1,800 rpm at 100 kph ng 5 speed same lang ng rpm ng 6 speed transmission ng Ford at 100 kph.
    Dec 2008
    #11208
    Quote Originally Posted by reddik2017 View Post
    Natatawa lang ako sa observation na "But definitely, the ride quality is not carlike and somewhat bouncy even on smooth pavement"
    Smooth pavement...bouncy? First of all why expect a car like ride from an SUV more so on PPV.
    Oct 2008
    #11209
    Organizer box
    Sent from my SM-N9005 using Tsikot Forums mobile app
    Mar 2005
    #11210
    Anyone experienced the door handle lock not working? I’m also getting a Turn The Power Off warning message each time I fold the side mirrors:turn off the engine. I think they could be related.
    #11211
    I have read the updated brochures for the blue power d-max and mu-x then found out na nasa 76ltrs yung tank capacity ng d-max while yung mu-x nasa 65ltrs parin? Lol bakit di pa nila ginawang same na lang? Kasi yung ibang ppvs more or less nasa above 70ltrs eh maliban sa bagong monty na parang nasa 68ltrs lang ata.
    toinks wrong thread...
    Sep 2009
    #11213
    Different strokes for different folks.
    The 18s look SO MUCH BETTER than the 16s in my opinion.
    if you want to change your 16" to 17" I can sell my stock
    Sep 2010
    #11214
    Quote Originally Posted by dennis22 View Post
    Am interested Sir in your 17 rm, 16 lang sakin eh. Location mo Sir, and hm? N.Ecija ako.
    #11215
    Ang porma na talaga sa loob ng 2018 mu-x sa china. Naging luxurious na din yung dating, di na tulad ng dati na may pagka-utilitarian.
    mu-X牧游侠图片_五十铃_汽车图库_手机汽车之家
    Sana dalhin na agad ng IPC rito kaso mukang matagal pa bago mangyari yun.
    #11216
    China is now the worlds no1 auto market so expect the models to be released / available there to have all the bells & whistles.
    Meanwhile, in the PH. Expect models sold here to be “watered down” to satisfy the price sensitive market.
    did you check the specs?
    Sep 2009
    #11218
    Quote Originally Posted by janalla View Post
    Manila ako sir, 1 month lang gumulong yung stock nagpalit na ko ng mags kasi agad.
    Sep 2014
    #11219
    mas maganda yun bluepower dito. from what I can see sa mga photos sa link
    yun power windows buttons, diresto pa din dyan, yun sa kin pataas, 45 degree angle, mas accessible
    no snap on compartment sa top yan
    no upper glove box compartment yan
    it used the updated TBZ aircon control config, for me mas ok pa din ang dial type. ang comment nga sa bagong TBZ ngaun, parang crosswind lang daw yun aircon controls lol
    and the touchscreen, it doesn't even fit the dash. anu ba yan? the current 8in Touchscreen looks more elegant in term of positioning, katulad ng ranger wildtrak ko.
    sorry but that china version looks cheap
    #11220
    Yung design ng dashboard ang tinutukoy ko OB, tsaka yung panels din kasi yun nga ang nirereklamo dati diba? And syempre, mas malakas parin yung 3.0 blue power kaysa 1.9 blue power.
    Nung unang labas yung d-max at mu-x, mapapansin na agad sa interior yung materials eh. Nung napansin ko yung quality ng plastics, naramdaman ko na parang may pagkahawig sa 2nd gen na avanza. Tadtad siya ng hard plastics tas di gaano appealing yung tunog sa pagsara ng pinto. I know kasi my fam used to have a 2012 avanza and ganun yung build quality compared sa innova.
    Ngayon ginawa na nilang leather or soft pad sa dashboard kaya mas um-ok na yung feel. Pero di ko parin trip yung dalawang vents sa gitna tsaka yung a/c dial. Parang ang generic kasi tingnan eh. Hindi premium, di tulad ng nasa china ngayon, at least mas sarado na sa hitsura ng mga nasa competition.
    Di na sana sila gumawa ng update na yan kung maayos naman pala yung unang design sa tingin ng karamihan. At least ngayon gumawa na sila ng paraan para mabago yun.
All New Isuzu MU-X // Alterra Next Generation
