Results 10,151 to 10,160 of 12125
August 27th, 2017 07:44 PM #10151
- Oct 2016
- 5
September 5th, 2017 10:42 PM #10152Hi mga sir, normal lg ba marinig yung clamping of gears when shifting sequence of reverse and drive? Ls-a 3.0 unit ko, wala nman problema sa pagtakbo...13000 na odo ng unit, first car ko kasi to pero bihira ko lg ma drive dhil sa abroad work ko kaya no idea ako kung normal lg ba to sa automatic tranny, sabi ni misis since daw pagkuha ganyan na at normal lg daw sabi ng casa, please advise mga sirs...ty
Sent from my ASUS_Z011D using Tsikot Forums mobile app
September 5th, 2017 10:54 PM #10153
hindi patag siguro ang parking... some AT have this issue. even the new fort has this. and the fort guys have a sequence how to avoid it.
- Oct 2016
- 5
September 5th, 2017 11:13 PM #10154Kahit patag po parking at talagang we make sure na nag totally stop ang car bago mag change gear...anu po sequence they use to avoid? Plan ko rin dalhin sa casa d next ff days pag d na busy...thanks po
- Sep 2008
- 295
September 6th, 2017 03:57 AM #10155Hindi na ako maka-mirror ng screen sa HU using my iPhone after updating to iOS10. I was able to before the update (LS-A/AT 2016)
Meron po ba kayong similar experience? We're you able to solve it? I hope you can share how.
TIA
- Oct 2005
- 29
September 8th, 2017 10:32 AM #10156may 15° slope sa kalye sa harap ng garahe namin. eto po ginagawa kung mag-park sa kalye:
1. full stop,
2. with foot on brake, shift to N,
3. pull hand brake until engaged,
4. slowly release foot brake,
5. if mux rolls forth or back, full step on foot brake,
6. pull hand brake one or two notches, as possible,
7. slowly release foot brake,
8. repeat steps 5 to 7 as necessary until mux stays put after step 7,
9. shift to P.
pa-correct na lang po kung kulang o sobra. hope this helps...
- 54,281
September 8th, 2017 10:42 AM #10157step on brake until full stop.
N.
pull handbrake.
release foot brake.
if still moves, pull additional 1 or 2 clicks on handbrake, until stop moving.
put to P. you know you have to put to P, if you want to pull out your key.
you can vary the steps. the end is the same.
i have a couple of dos por doses in the trunk, justin case... (wheel wedges!)
September 8th, 2017 05:22 PM #10158
September 8th, 2017 06:28 PM #10159
baka ibang gear oil gamit. ginamit nila gear oil for the trucks..
Sent from my SM-G935F using Tsikot Forums mobile appLast edited by StockEngine; September 8th, 2017 at 06:50 PM.
September 9th, 2017 06:35 AM #10160
Kung sirain mga modern releases nila, edi walang pinagkaiba sa ford.
China cars
