Results 1 to 4 of 4
June 27th, 2009 10:30 PM #1Mga sirs, tanong ko lang po saan pwede bumili ng Tire Fenders para sa 96 isuzu ls pick up ko? second question nagupgrade po ako ng headlight from standard 55/65 W headlight to 90/100W halogen headlight without upgrading any wiring and relay and it works fine. In the long run po ba ok lang ito? please advise po. Thanks in advance.
June 28th, 2009 12:30 AM #2
dapat e wiring kit mo yan... masusunog wire mo yan.. mas maganda kung malaki ang wire para mas maganda ang output...
June 28th, 2009 02:08 PM #4
di ko masyado na compute kung magkano ang wiring kit pero estimated lahat na bayaran ko mga 3k-4k(bosch wiring kit, ung wire is high-end ang ginamit, socket, european horn, 2pcs halogen 100/80W, labor) di ako sure sa price kasi tagal2x na rin....
high idle RPM at engine start
