Results 1 to 20 of 42
    May 2004
    ah okay get the 1kzte if you have the budget.
    around 115HP*3600rpm; 295Nm*2400rpm.
    Feb 2011
    Quote Originally Posted by RakataK View Post
    masyadong maliit at magaan ang owner type jeep para sa 4JB1. 2.8 na diesel yun para kang nakasakay sa jack hammer niyan kahit maganda pa ang suspension mo.
    Quote Originally Posted by niwde11 View Post
    sa blumentrit ba yan sir?? compare ko na lang siguro mga nabigay niyo na model hehe pag napadpad ako next year pa naman ako bibile hehe
    Jun 2004
    hi sir,
    FYI, the 1kzte uses a computer box. you might get the engine cheap but the electrician will charge you an arm and a leg for the installation. friend of mine spent 15k on the electrician labor and materials. and the 1kzte may be fast but its not as fuel efficient as a 4jg2. cuz the 4jg2 is direct injected. but the 1kzte runs smoother because it still has a pre combustion chamber unlike the 4jg2 (direct injected).
    Another consideration you should consider is the vibration of the engine. Malakas ang vibration compared to a gas engine.
    May 2004
    mints, 4jb1t is direct injected. but afaik 4jg2 is not. i maybe wrong though
    You are correct on both sir niwde.
    Feb 2011
    4JX1T ang direct hehe
    pero kung wala akong mahanap na 4JG2T baka mag SR20DET na lang ako
    since timing chain din siya
    Quote Originally Posted by jctapit13 View Post
    ayaw talag ni sir ng timing belt ha. hehe. To each his own nga naman.
    Jun 2004
    thanks for the info. all the while i thought all of the 4j series were direct injected.
4JB1T Engine
