Mga Sir's paano po ba malalaman if na break-in na po ba ang isang engine? TIA po![]()
Hello mga sir ask ko lang may naririnig kasi akong noise coming from transmission parang nag huhumming sya kapag naka shift na sya from 1st gear to 5th gear and reverse pag naka neutral wala naman ako naririnig na humming. naririnig ko lang yung humming sound kapag umaarangkada na kapag binitawan ko naman yung accelerator pedal nawawala yung humming sound atsaka ang hirap ipasok ng kambyo parang may sabit tapos yung clutch ko parang ang tigas.
This might help you.
White smoke is normally ‘steam’ which means water is vapourising! If it is white ‘smoke’ then it could be as a result of low engine temperature. White Smoke will smell of unburned diesel - White ‘Steam’ will not!.
AFAIK, puwede lagyan yung old school diesel ng 2T sa fuel tank para makatulong sa decarbonizing. 128:1 ang ratio para safe. Done it already. No problems so far. Still checking the FC if it will improve but i doubt it. Decarbonize lang talaga.
http://www.dieselsmoke.com.au/
Fasten your seatbelt! Or else...Driven To Thrill!
sir 128 ml of 2t is to 1 liter of diesel? ganun po ba ang ratio? sorry newbie![]()
