Results 1 to 9 of 9
- Sep 2005
- 9
October 26th, 2006 11:17 AM #1effect of typhoon milenyo.
plan to replace DIY, kelangan ba nakapaste yung foam sa
flooring?? or yung foam sa carpet?? if so, what kind of adhesive
ang ginagamit?? please advise
October 26th, 2006 04:33 PM #2
Foam sa carpet. Rugby (contact cement) lang gamit ko (kaya high na ako afterwards).
Try mo maghanap ng foam na isang sheet talaga, yung iba kasi yung 'recycled' using chips of old foam, dumadapa pag-tagal. Pero kung ok lang naman yung sa iyo, pwede na din.
- Mar 2004
- 153
October 27th, 2006 03:39 PM #3Foam - you can buy this from Uratex since all automotive foams come from them.
Adhesive... walang choice kundi rugby
- Sep 2005
- 9
October 31st, 2006 01:55 PM #4
October 31st, 2006 02:03 PM #5
Cut your foam into sections to make it easier. Huwag mo idikit sa floor. Hassle kapag kailangan alisin ang carpet (e.g. nalubog sa baha or may natapon na liquid sa loob ng sasakyan. Pwede pa pagmulan ng kalawang yung carpet pag dinikit mo sa floor kasi hindi mo pwede ibilad pag nabasa.
- Sep 2005
- 9
October 31st, 2006 02:24 PM #6yup i will cut it into pieces, but not the carpet...anyway ilalatag ko na lang
muna in place yung per piece ng foam sa floor, then i'll put cement sa ibabaw
tsaka ko ipapatong ng buo yung carpet...ok ba yun??
October 31st, 2006 02:28 PM #7
Ok na yun. That will work. Lagyan mo ng cement yung both surfaces to be stuck together. Let it cure for 30 mins before bonding.
Tapos put something heavy on top (e.g. big textbooks) para dumikit ng maayos.
- Sep 2005
- 9
October 31st, 2006 02:33 PM #8ok sir sana matapos ko na this holiday.
dami pa kse inayos sa engine,sounds at electrical wirings dahil sa baha..
this week upholstery na...thank you very much!
kelangan i-DIY wala na budget eh
October 31st, 2006 02:37 PM #9
Ok lang, masaya naman mag-DIY. hehehe.
high idle RPM at engine start
