Results 1 to 20 of 21
    Jun 2006
    How do you properly dry a soaked carpet?
    May 2005
    Ideally you got to take it out and leave it to air dry (under the sun, better). In the end, it depends on the severity of wetness/moisture the carpet has been exposed to. Hope you can provide more details.
    Jun 2006
    Yung 2nd row ng avanza ko eh nabuhusan ng mga bata ng pitcher ng tubig. Basa yung matting and carpet. Tried to clean up by using a MF towel to soak up excess water.
    May 2005
    If its the floor carpet is soaking wet (as in a puddle of formed after the spill) then it is advisable remove the carpet (usually its the entire panel) and air dry it. That way, you'll be sure it that it dries up completely. If you leave it on the vehicle to dry, it would take longer to dry and you can't be sure for certain if it dried up already.
    If the "wet" carpet did not completely dry up, it would leave this really foul odor that would linger in your car until you have the carpet washed and completely dry. This happened to one of our cars. It still has an odor and we're to lazy to remove, wash and dry the carpet. :D
    Jun 2006
    no puddles naman. right now its damp. is it ok to put a towel on top to absorb the water? Wala kasi akong hair dryer o heat gun o wet vac man lang.
    How do you remove the carpet? Looking at it, i think I will need to remove the seats to pull out the carpet.
    Jun 2006
    ok i removed the towel and replaced it with an electric fan pointed directly at the carpet will leave on over night hope this works.
soaked carpet
