Page 3 of 6 FirstFirst 123456 LastLast
Results 41 to 60 of 120
    Jul 2013
    #41
    I bought a generic phone holder from Ace and used this to stick it to the dash board hehehe
    Mar 2013
    #42
    Quote Originally Posted by wewoy_romero View Post
    i also use a mountek cd slot pero clip type yung sa phone hindi magnet. would like to try the magnet type kaya lang ang takot ko baka hindi ganun kalakas yung magnet at baka matanggal yung phone habang nagddrive ako.
    matagtag pa naman sasakyan ko. yung mga naka-magnet type, kaya ba niya yung note4 + otterbox casing?
    question lang baket ka magpapalit ng magnet type? di ba maganda clip type ng mountek?
    #43
    I also have a Note 4, with a Spigen case. No problem at all with the magnet mount as long as nasa gitna yung magnet para even weight distribution.
    Quote Originally Posted by 99moves View Post
    Magnet mounts are much, much more convenient than grip mounts. Hassle yung may pipindutin ka pa para magbukas yung grip, not to mention it looks so bulky.
    Magnet mount, dikit lang, and you're off. Looks much cleaner too.
    #44
    hindi kaya sa otterbox.... yung sa akin spigen lang, mahina na.
    would those mountek magnetic mounts work w/ smartphones w/c have curved back designs?
    iyong aking asus zenfone 2 kurbado iyong likod eh. ergonomic daw kasi ang hugis
    #46
    i'm using a mountek ngroove grip cd slot car mount on our fd. it's been great and i want to use another one this time for our monty naman. the problem is the ngroove grip variant isn't a fit w/ the monty's interiors since the head unit is relatively positioned deeper than the other usual oem head units
    so my question is, is the mountek snap + magnetic cd car slot useable in the monty '12 dashboard layout? is anyone here using one in the previous generation montero sport?
    btw, there's already a mountek air snap wherein the mount is positioned and clamped on the a/c vents. the problem is it's only available in the usa at the moment. its worldwide release was scheduled a few days back so i doubt if it's already available in the country and i'm not sure if it'll work on the monty's a/c vents although it's supposedly universal though
    Meron china copy sa olx bro for only 350 php
    Not an exact copy but works just the same.
    #47
    Kung alanganin kayo sa likod ng casing nalang lagay yun metal. Medyo masagwa nga lang
    Apr 2006
    #48
    mountek nGroove pala yung tawag sa gamit ko.
    Apr 2006
    #49
    I borrowed a friend's magnetic mount to compare. Di daw niya ginagamit kasi sobrang hina daw ng magnet. I tried it for myself. And yes, madali nga matanggal when driving on not so smooth roads. Sabi ko baka dahil yung metal nasa loob ng case. So i tried sticking the mount sa ref. Madali pa ring matanggal. So magnet nga ang problema.
    Posted below yung aking mountek ngroove na clip type at yung magnetic type. Both cd mount.
    #50
    What magnet did you use for your Mountek? This is what I have for my Note 4:
    I have also tried putting the magnet inside the phone (since the rear cover is detachable). This way, you can mount the phone even without a case.
    #51
    Air Snap already for sale at GadgetPinas:
    Mountek | GadgetPinas.ph
    #52
    I stopped using my mountek. Dun kasi sa IP5 ko once naka mount siya, may instances na the phone will restart again and again.
    Inobserbahan ko, nangyayari lang talaga pag naka mount dun sa mountek. Coincidence or not? I don't know.
    I changed phone.
    I'm using IP6S Plus, bumper lang case ko. Ang sagwa if ilagay ko yung steel plate sa likod since sa phone na siya mismo ididikit hehe naghahanap pa ako mumurahin na case na pede pagdikitan. Kaso pag naaalala ko yung nangyari sa previous phone ko kinakabahan naman ako.
    #53
    Yung sakin bro hindi naman nagkakaganun. I've tried it with an iPhone 4S, iPhone 5, iPhone 6, Note 4 and Note 5. Never naghang or anything unusual.
    Hindi kasi dapat naaffect ang phone kasi purely flash memory lang yan. Hindi kaya dahil sa init kaya naghahang? Baka nakacharge phone mo habang nakamount?
    yep i already checked out that site yesterday but the curved back design of my cel may deter the earth magnet from doing its job effectively that's why i'm leaning towards getting the iottie easy flex 3 na lang
    #55
    O buti you pointed that out! I forgot to mention the phone is plugged in too hehe habit ko na din kasi na naka charge yung phone basta nasa kotse ako.
    So that's the culprit then? Bakit kaya?
    Cable problems? Im using genuine cables naman.
    Sorry OT.
    Yep baka nga dahil naka charge.
    #56
    iPhone 5 ko madali magoverheat pag nakacharge tapos nakaWaze. You should also check your car charger. If it's generic, could cause hanging. If high-amp na branded, ganun din mas madali uminit kasi mabilis magcharge.
    #57
    OK naman yung ganito ko from olx, generic/china. wala naman problema using xperia T2 Ultra 6"
    di kaya malaki or mabigat lang yun phone na ginagamit?
    Apr 2006
    #58
    hindi mountek yung nahiram ko na magnetic. yung metal inserts sa phone plain/generic lang. manipis nga eh. baka yun reason kaya mahina kapit.
    magnet din ba yang nakadikit sa phone?
    *ninjababez
    i use a note2 for navigation (waze). same weight lang sila halos ng note4 ni jut. and yeah, generic china from olx yung nahiram ko. thinking baka better kung mountek brand baka mas malakas ang magnet.
    #59
    *ninjababez
    Hmmm baka lemon? May lemon nga na magnet? hehehe
    Apr 2006
    #60
    sinubukan ko sa loob ng battery cover ng note2 nakalagay yung metal pad tapos walang protective case, nagslide pa rin pag nagvibrate ng konti.
Magnetic Mobile Phone Mount
