Page 8 of 14 FirstFirst ... 456789101112 ... LastLast
Results 71 to 80 of 138
    Dec 2017
    #71
    yes, overseas. lonely indeed[emoji40]
    Are you land-based or at sea? I can relate as I'm stuck here on my work and I can't go home. It has been a month already! I used to work abroad but for a weak hearted guy like me, I truly can't stay for that kind of work even if the pay is good.
    Going back, it was a good timing for me that I covered the car before I left it. I never thought I'll be stuck here for over a month.
    Hopefully, no rats and cats will make the engine bay its home and playground.
    [emoji3]
    Apr 2012
    #72
    [emoji3]
    landbased bro.
    btw, no idea how to remove scratches sa step sills in your previous post. since inaapakan naman, you can just clean it well then put the plastic cover you bought from Blade.
    Feb 2019
    #73
    Just saw this on fb.... has anyone tried using this? Its a foam cleaner and virtually cleans everything inside your car.
    Jan 2008
    #74
    Depends on the surface you want to clean. Try pro choice products.. been using them to clean my cars.. for interior plastics try pro choice all purpose cleaner. Dilutable so very economical.. very effective in removing "libag" hehe.. then apply sunshield to rejuvenate and protect the plastic.
    For carpet or fabric, just use liquid detergent mixed with water.. brush the carpet with microfiber cloth then use a wet and dry vacuum to dry clean
    Feb 2019
    #75
    Yes I have seen that pro choice by microtex I think 10 liters of water for 1 liter of pro choice right? and microtex also have this ready to spray quickleen seems like just the same.
    Feb 2019
    #76
    Can I use the quickleen and pro choice to clean the car ceiling? If yes please guide me on how to go about it as to not damage the car ceiling because its dirty especially near the rear aircon vents. Thank you
    Apr 2012
    #77
    try it first in a small area of your car ceiling and then see for yourself the result. if it do its job and not showing anything abnormal then its safe to use.
    Jan 2008
    #78
    NO..
    Eto tried and tested ko na.. warm water with liquid detergent (breeze blue) mix it well..medyo tapangan mo yung detergent then use a soft microfiber towel and gently wipe the ceiling. Very gently!! Pat the wet towel into your ceiling. use hair dryer to warm the ceiling till dry
    Feb 2019
    #79
    NO..
    I see. We are using ariel and surf powder. I tried the quickleen to clean the sidings and headboard and it gets the job done those hard to remove stains in the floor sidings are gone just need to use a toothbrush to scrub it a little bit. Thank u sir.... will try it at the back small portion im scared that i might not came out well.
    Jun 2005
    #80
    Bumili ako nung rivers na degreaser sa lazada noon. Netong quarantine, nagspray ako ng ng kontinsa ceiling then wipe. Mabilis lang. Tanggal yung dumi agad eh.
    Sent from my MI MAX 2 using Tapatalk
DIY Interior Detailing
