Results 1 to 10 of 14
September 10th, 2003 03:39 PM #1
Guys,
Plan to DIY my interior bumili na ako meguairs APC and eagle one leather cleaner and conditioner. My question is I have tried cleaning the seats but ang lagkit ng residue... bakit ganun.. gamit ko is eagle one should I dilute it with water? what i did is to wipe it with rug with water after bumubula pa nga... then tsaka ko na lagyan ng conditioner.
Overall I am not that satisfied with the cleaness and plan to do it again hehehe anong brush ang magandang ipanglinis sa leather seats? takot ko kasi baka masyado magaspang yung brush kaya nung brush ko parang may mga lil pieces na natatanggal sa leather is this normal???
With regards the dashboard/sidings never used armor all since lalo ito prone to dust. What can i use to protect this from fading but don't want the same sticky feeling like armor all.
btw my ride is trooper which has a beige interior.. deym hirap linisin.
thanks in advance for your advice.
- 10,620
September 11th, 2003 10:52 AM #2mdpo,
sa interior isa lang ang panlinis ko
(3M) or any other Multi-purpose Cleaner
plus a good morning towel and toothbrush
just spray the cleaner sa towel then rub vigorously area
portion by portion dapat
after cleaning the apply the sealer/conditioner/what have you
- 99
September 11th, 2003 11:08 AM #3md instead of a brush sa leather, try using cotton towels with your cleaner. the brush might scratch nga the leather.
i use diluted meg apc sa vinyl and abs plastic ng dash and sidings. spray it lightly using atomiser, scrub the spot with toothbrush, then wipe clean with cotton towel. you may want to spray pure water using another atomiser so that the apc is totally rinsed out. basta wipe lang kaagad para hindi messy and hindi mag dry up which can cause ugly streaks.
- 10,620
September 11th, 2003 02:47 PM #5yup!
nga pala i dillute also my multi purpose cleaner
.25 solution .75 water
September 11th, 2003 05:00 PM #6
never use multipurpose cleaner (or apc) on leather even if it's diluted, you'll discolor it really fast...
also, rubbing fabrics is not a recommended procedure coz you'll only be rubbing the dirt into the fabric and foam, and not removing it.
- 99
September 12th, 2003 06:34 PM #8
what kind of cleanser do i user to clean plastic moldings and sides?
September 12th, 2003 07:03 PM #9
ok lang irub, but it highly depends on the leather type, some are coated and some are not... Pajero leather is poorly dyed and discolors even with soap and water, so leathers of such type should be regularly wiped clean coz it's hard to clean it thoroughly but safely.
September 12th, 2003 10:20 PM #10
Thanks theveed.. leather yung sa trooper ko.. hirap nga linisin eh. Maski di nagagamit it turns black what can u recommend? daily wipe of clean cloth with wateR???
I've looked into it before but changed my mind. On paper, they run circles around lead-acid...
Lithium-ion Batteries?
