Page 1 of 2 12 LastLast
Results 1 to 20 of 33
    Mar 2003
    a friend is asking me to find him a 2nd hand Starex ('99-'00). Is it a good buy? since i'll be looking at a 2nd hand car, what are the most common problems you've encountered or heard of?
    Feb 2003
    well, i have an starex 99 turbo intercooler A/T here are the pro's and con's
    pro's
    1. space! it's huge inside... kahit apat pa isakay mo sa second row kasyang kasya. pag habol mo space.get the starex.
    2.convinience... kun meron ka lalagay na malaking gamit sa likod, you can eaily fold the third row in one minuite , and just think, yung space na malalagay mo a likod X3 sa trunk ng car, i mean its huse too, unlike ford club wagon na kailangan tools pa ang gamit to fold the third row
    3. good family car....ndi ka magsisisi dahil pag ndi maganda ang starex, walang bibili....este wala ka palang makikita sa kalsada
    4.proven diesel engine..... 1 of the best diesel engine i,ve driven, and best of all, it is powerful, kahit paakyat na super steep, aakyat pa din, ndi iiyak ang gulong.
    5. value for money.... wala pang 1M and sulit, unlike others ( hi-ace grandia, sedona, venture)... they cost 1m plus
    6. malambot upuan
    7. excellent suspension! it has much bigger tires, and coil spring, and mas maganda kapg mas mapigat ang van, dahil kapag mag isa ka lang nagdadrive, sobra malakas body roll pag dumaan ka sa uneven na road...
    8. cold aircon....ndi ka kakapusin sa lamig.
    9. marami na spare parts availale
    10. mas ok diesel compare to gas at this time dahil mag cheap ang diesel.
    11. wala ka problema sa smoke emmition test provided you take proper maintenance in car..
    12. very useful!
    13. intimidate due to huge size
    14.maliwanag! malakas fog lamps
    15. soft steering wheel
    con's
    1. shift shock for A/T
    2. slow acceleration even if it's turbo charged.
    3.takaw sa mata
    4. cheap plastics and fake wood inside
    5. not so good mileage , i only get 1 is to 6...
    6. blind spot front right side..kailangan masanay ka to get used to
    7. weak brakes!
    8. korean tires is very bad, mabilis mpudpod!, (HANKOOK) , better change it to bridgestone D
    9.underchassis sometimes produces sounds, pero hayaan mo na lang, mawawala lang yan.
    10. madaling masira ang door handle, be care ful na wag mong bibirahin ang door handle kapag naka lock pa yung door, lalo na yung mga gagong security guard, sometime pinipilit nilang buksan even if it's still lock kaya nababali, and another thing is, wag masyado magalaw sa interior na light lalo na yung sa taas ng second at third row, madalas mag stuck ang buttons!
    that's all, kun meron pa akong nakalimutan ipopost ko na lang, ang anyways opinion ko lang ito.... P
  3. FrankDrebin Guest
    isa pang cons
    hirap mag-yosi sa likod kasi walang mabuksan na bintana.
    Mar 2003
    thanks, mk. how 'bout mechanical parts? i've heard there's problem with idling or with the aircon, totoo ba ito?
    naaalala ko sa mga old topics sa kotse.com marami nang ganitong topics, i dunno if its true pero may mga nag comment dun na madali raw kalawangin ang mga starex? maybe it has something to do with its rustproofing.
    It's just like owning a Mitsubishi.
    sauman,
    The rust problems have been solved in the Millenium Series (the ones with the big chrome grilles).
    sa mga korean cars/vans, generally yung mga parts are more easily prone to wear and tear. mas mabilis palitan compared sa mga japanese.
    Feb 2003
    ha! frank drebin is right... malit lang ang kaya ibksan na window sa likod, pero its a good thing becoz para makaiwas na din sa "bukas bintana gang", dahil pag sliding type yung window sa likod (like hi-ace) , kaya ito buksan usinga long sharp thing..about hbk, yes, yung idling nagloloko din, pero a adjust mo lang sa may makina.... and about the aircon, sa akin cooling coil pa lang nasisira so far 5,500 php $$$ damn..., dagdag ko pa sa pro's is ang starex mas ndi prone sa overheat, tatlo kasi ang fan sa makina, 1 big fan and 2 auxilliary fan..
    Some owners overlook the fenders when cleaning their cars. Dito madalas nagsisimula ang rust left and right front fenders. What I like is the A/C, ang lamig! Plus yung seat config ng 9 seater versions, pwede ihiga ng flat at maging kama from 2nd row to 3rd row. Just like papa tots pointed out, I have changed brake pads front and rear from 3 years of use. We got Kumho brand tires, after 2 years bumukol agad, so I changed them to wider specs at 225/70R15 and switch to a much reputable brand. And I also like the roof rack capacity, 80kgs. at max weight, (I tried to jump on it and not a bent!). Not like some other vehicle brands where a warning sign is sticked "For Display Purpose Only!"
    I'll just add about the engine, it has oil cooler! Kaya hindi ito prone sa overheating even while the van is on idle with A/C on.
    Isa lang ang solusyon diyan - use Mitsubishi parts. :D
    Jan 2003
    Add ko lang sa Cons. Medyo hirap umakyat yung gamit ko papuntang Baguio. Pag steep ang grade ng road gapang siya. Malakas talaga yung makina lalo na sa highway pero pagakyatan para siyang hirap. Baka naman dahil puno kami? Pero tama sila lahat - malakas aircon! Kung di lang mahirap ipark at idaan sa small streets ito na ang magiging favorite car ko.
    Feb 2003
    yung starex nakakaakyat pa rin kahit steep... just shift yuor gear to "L", and one good thing is that meron itong LSD-limited slip dfferentials so pag oras na dumudulas yung front na wheel, nag a asist agad ang rear na wheel.... so di umiiyak ang gulong.........correct me if i'm wrong..:mrgreen:
    Mar 2003
    thanks sa mga reply, far mukhang ok naman mga feedbacks nyo, sige, simulan ko na car hunting.
    Mar 2003
    Otep, pwede ba talaga mitsubishi parts?
    mk,
    a run-of-the-mill starex is rear wheel drive, so an LSD functions only when a rear wheel slips. actually, an LSD is pretty useless in the city, wala naman tayong snow dito, a wet road won't be too much of a problem even for non-LSD-equipped cars, and i don't think you'll be taking a starex off-road
    dagdag sa cons:
    - you see six of them and one just exactly like yours at every intersection
    - it's significantly taller than the minivans (venture and sedona and T&C) and aren't as good-handling on the road as those (no surprise there)
    - only one sliding door
    - crash safety is marginal (particularly against big heavy objects), the Sedona is MUCH safer than both the starex and venture
    and sa pros:
    - parts and service is no problem, unlike the minivans
    Feb 2003
    and one more thing, mas mahal ang 9 seater na starex compare to 12 seater na starex due to it's suspension, 9 seater is coil spring then 12 seater uses leaf spring.., mas matagtag ang 12 seater.........but if you have extra bucks to burn, go for the starex club. mga 1M , which is leather seat and captain seat ang second row...:roll:
    Yup, rebodied Space Gear ang Starex. Pero halata pa rin sa front quarter window at side mirrors ang kanyang family history.
    mk, mbt,
    The LSD is useful for backing up steep driveways or ramps or sa grass during picnics. Lalo na kung madulas. Sa mga ganyang sitwasyon. Wala nang ibang ginawa ang Besta ko kundi dumulas.
    I have driven a 4X4 Club. Sarap dalhin parang Pajero. Ang taas pa.
    Dreamcar ko nga 4X4 na SVX, eh. Pero masyado pa din mahal and nakahanap ako ng Pajero at the right time and the right price.
    Quote Originally Posted by mk
    The main reason why the "Jumbo" is cheaper from the RV models is the current tax scheme our government implies on automotive industry. Minimal seat configurations means more tax and vice versa. So the lower the passenger capacity, the higher the tax.
    Then add the amenities the RV has compared to the Jumbo ones.
    Feb 2004
    mga sir: somebody mentioned - shift shock - sa cons, ano
    po ba ito?
    i have an a/t starex, pag binigla mo apakan ang gas pedal hindi siya nagrerespond kaagad. in fact parang over rev ( kung sa m/t parang hindi pumasok sa gear at parang nasa neutral pag apak mo sa gas )
    but i've learned to live with it, kaya alalay lang ang apak ko sa pedal (timplado ko na). i assumed it's just the way it is. can you guys enlighten me on this. tnx
What can u say about Starex?
