Originally Posted by
batang_raon14
GPS-wise as long as you're not under a tunnel, reception's pretty much quick (placement of the antenna though may affect satellite lock-in time). If it's Windows CE-based (which most of the China GPS headunits are, there a high possibility that you can install Garmin. There are a lot of guides over the net (Google query works), checking some threads here will also guide you into successfully installing it.
For actual pics I don't have any (purely on the basis I don't own a Tucson to begin with), but specs should rather be the same on all units. You can query Alibaba.com for IX35 or Tucson and chances are you'd find one showing actual pics. Good luck.
NOTE: if you're planning to soup-up your sound system, there's a probability that you'll hear a low and static noise (similar to the tone of that medical monitoring equipment once someone flat-lines) once you've un-mute the volume especially for those with amplified setups. We tried to add additional grounding in our fleet before, insulation, and review of the wirings as to where it's coming from, until we found out that the main RCA-outs of the HU were the culprit. I think 8 out of 10 units had that issue in our fleet then, just can't recall.
Made our fleet management and monitoring systeam real cheap though. HTH
