Chineck ko ulit yung fog lights ng santa fe namin and malabo pa rin siya. Hindi ko sure kung moisture yun or baka lumabo na yung plastic dahil sa init ng ilaw
And napansin ko 2 pala yung light bulb sa fog lights area pero isa lang umiilaw?
Happy new year mga katsikot ill be having my 2nd PMS of my SF3 next week magkanu kaya magastos ko?..
TIA.
Three members here in the same forum installes DRLs already. Just back read. Also with HIDs. As far as I know warranty will be voided.
Guys magkano inabot ang 20k checkup nyo for your Sta Fe 2013? Malapit na kasi ako magpa service. Thanks
Sirs, my new plates will arrive soon. For the rear I'm somehow convinced na hassle-free yung pagkabit ng special bolts that come from LTO since may welded nut na tayo dun, but how about for the front of our SF3? IIRC plastic yung tread for the plates there at walang nut sa kabilang side nung black front bumper.
Are you pertaining in to this? (the one encircled)
It is an ambient light. In a completely dark environment it does neutral lighting to illuminate the center console quite well. In the absence of any other light (interior lights, street lamps, etc.). It is even featured on Sonata, On higher trim models it's a good little feature to have.
ambient light also known as pin lamp/light...regarding about the red light blinking on the top center of the dashboard towards the windshield with a shape like a gps antenna? yes, you're right it is an auto-lamp/illumination sensor...you can try if it is working, just cover the area with something dark, if the headlight turns on then it is equipped.
Mga sirs, I have 3 weeks old santa fe gen3.Normal lang ba na may white visible smoke?TIA
