Results 1 to 17 of 17
    Nov 2007
    just want to know if anybody has expirience the same thing as I,.,.,napansin ko kasi that during some rainy days our SF got some moisture trapped in both headlamps..,,,.and after a while kapag ok na ulit ang weather mawawala din siya without leaving any mark,.,.,is there anyone expirencing the same thing here? fellow SF owners?
    I already let my dealer know about this problem eversince we got our SF but they're advicng me to take some photo shot of it to justify coz kami pa lang daw ang nakaexpirience ng ganun.,.,.after a long time of more than one year ngayon ko lang natyempuhan ang moisture trap na yun tsk tsktsk.,.,
    I experienced it too pero maliit lang so di ko na pinansin as opposed to disturbing the dealer and getting headache trying to prove my point I decided it wasn't worth it... Yes it also happens on cold days or rainy days pero kung wala naman ulan it never happens...
    Merong isang Sta Fe owner is Innova Boy ata yun grabe yung sa kanya parang pinasukan na ng fog yung headlamps nya. I think sakit nato ng Santa Fe headlamps its just a matter of matindi ba or maliit lang...
    Nov 2007
    thank you sir tidus hindi naman pala ako naiisa eh.,..i just want to share here are some the photo shots i've taken with my phone cam.
    Yeah more or less ganun din sakin mas maliit lang siguro ng konte. After an hour nawawala din naman eh...
    Gud evening po. Ganun din po observation ko sa headlights ng SF ko. Pag malamig or umulan and mainit po makina, magkakaron ng moist sa loob ng headlights. Pag mainit na weather, nawawala rin. Naisip ko baka trapped moisture sa loob ng headlights, so I tried to blow some hot air inside the headlamps thru the socket of the high beam bulb, para mag evaporate trapped water/moisture. Pero bumabalik pa rin. Muka naman di po leak sa rubber moldings kasi di nalalagyan ng tubig pag umuulan o nililinis, talagang moist lang lumalabas. I'm suspecting now na baka sa pag linis ng engine, dun pumasok konti water thru the bulb sockets and na trapped na inside.
    Jun 2007
    Quote Originally Posted by tzulao View Post
    yah mine does that too. 5 days after i got my unit. the moisture will evaporate after a while. will only happen if you open the headlights right after a carwash. i didn't worry too much about it as the electricals were not affected.
    Nov 2007
    thanks guys for your replies.,.,.now i know na marami pala tayo na ganun ang headlamps,.,..,
    meaning sakit na ba talaga ng SF yun?
    BTW guys.,.,do you think the casa can rectify this..,.,though the electricals are not affected my worries are baka sa katagalan eh magiwan siya ng mark inside the lamps(stained headlamps)?
    I'm kind of hesitant kasi to bring this up again to my dealer coz they might ask me to leave my SF to them for checking.,.,. mamimis ko si Fe niyan tsktsktsk
    I think that it is worth the temporary sacrfice sir. Have it serviced nalang when you can make time for it.
    Normally to cure this problem they just take out the assembly, wipe the moisture on the insides or blow it with a heatgun. It can then be resealed with silicon.
    This happens even to the best of brands.
    Feb 2005
    I think this is a defect in the design of their headlights...
    Quote Originally Posted by Innova_Boy View Post
    Am not sure about that. I personally have not experienced the moisture problem since I got my unit back in 2007.
    Nov 2007
    oh my,.,.,halos puno pla ng fog yung loob ng headlamps niyo sir,.,.,.luckily hindi pa naman umabot sa ganyan karami yung sa akin.,.,.
    BTW sir have you got this rectified by your casa?
    Apr 2005
    hindi ko pa experience ang ganyan
    Naayos ba ng Casa ang headlight mo Innova?
    I haven't experienced this for a very long time now. Buti na lang, mukang its gone for good...
    i think design? im not sure. sa pagkakalikot ko kasi nung SF namin, napansin ko yung headlight assembly na parang may maliit na outlet (parang maliit na rubber hose). siguro singawan ng init? ewan. kasi yung iba naman naming sasakyan wala nun e. or meron, hindi ko lang napapansin.
    Apr 2009
    that's true.. medyo isa yan sa mga design flaw.. may na-release ako na ganyan din ang problem.. hindi ko alam kung kilala nyo sya.. si jose manalo ng eat bulaga.. since nasa media sya or have access to it our dealer decided na palitan ang unit.. ganun pa din ang nang-yari, may moisture pa din.. not cause of alarm naman yun actually, very minute particles of moisture trapped inside while the whole headlight assembly was being sealed. yun lang talaga cause nun..
    kaya yung sinasabe nung isang nag-post na ang sinabi sa kanya ng s.a. (service advisor) na to take picture... delaying tactics lang yun.. they should given him a good explanation lang..
    Oct 2008
    Quote Originally Posted by jav-jav View Post
    nako.. not to offend but that sounds unfair to most buyers na hindi pinayagang palitan yung unit na may ganung kaso rin dahil hindi connected to something sikat sa masa (like sa media or daily tv show for the masses)
    Apr 2009
    Quote Originally Posted by Burai View Post
    true... but still case to case basis pa din naman when it comes to palitan ng defective unit.. nasa pag-uusap naman kasi yan e.. kung ok ka sa dealer na pinag-kunan mo ng unit mo possible na ma-palitan unit mo.. pero kasi according to DTI when it comes to brand new cars ang pwede lang palitan is yung defective part..
SF moisture inside the head lamps?
