Results 1 to 9 of 9
- Sep 2012
- 4
September 3rd, 2012 11:02 PM #1mga sir,
may alam po ba kayo na mas magandang service shop,, at mura,
kasi yung starex namin 2005 model, sira yung radiator, hindi na umiikot ung tubig, kaya madali nang mag init
sabi ng taga hyundai center sa commonwealth, Q.C.
overhaul dw,, mag ready daw kame ng 100k,
parang ang mahal naman sobra,
pa help naman po,, san po ba pwede mag paayos,, yung mura lang.
Thanks
September 3rd, 2012 11:22 PM #3
Dalhin mo sa Keysar Radiator sa West ave. Iba na yata pangalan nila ngayon. Pati casa sa kanila nagpapagawa ng radiator.
You have the option for radiator repair. They will use plastic top parin. May parts sila. You can also opt to buy a brand new replacement radiator din naman na plastic top. Pero have your cooling system checked muna kung ano ba problema. Baka busted rad cap lang yan.
September 4th, 2012 10:17 AM #5
- Sep 2012
- 4
September 4th, 2012 06:38 PM #7ung cylinder dw mga sir..
my problema dw,
kaya ndi umiikot ung tubig
- Sep 2012
- 4
- Jun 2005
- 3,774
September 4th, 2012 06:52 PM #9parang malabo ng may sira ang cylinder kaya hindi nagcirculate ang tubig.
possible na hindi nagcirculate and tubig then becausr of overheat nadamage/nagwarp ang cylinder head, not th other way around.
pacheck ko muna ang thermostat baka stuck closed lang. kapag okay ang thermostat, next check the water pump.
high idle RPM at engine start
