Results 1 to 17 of 17
    May 2005
    just want to know what are good replacement tires for the GS' Hankook RA08 215/70 R16s.
    i was scouting for RA08s this morning in sucat and evangelista in makati but found none. all said there were no stocks of that brand and model. and then another added that it was discontinued already.
    i was hoping i could find one because i just need one to replace one of my front tires and intend to put the unused spare tire, also an RA08, on the other front side.
    but if i cant find an RA08, i'll probably buy 2 tires of the same make and model. preferably 6 ply also with same or better load rating.
    pls advise. thanks.
    From some research a month or two back, I think the Neuton (I forget the exact model) 225/70r16 will match the RA08's load rating, which is among the important factors due to the GS's weight.
    Yung Nexen pwede siguro. Pero hirap din maghanap nun. Try niyo Bridgestone kahit mas malapad ng konti.
    May nakita kasi akong gray market HVX (17" rims) naka-Bridgestone Dueler..
    Di ata kakayanin kung load indicator ang basehan. But then, also, if you don't load as much, tapos better branded tire, baka pwede na rin.
    Nexen at Hankook lang kasi may exact size para sa GS.
    I noticed walang hiya ang mga Koreano pagdating sa tires. Walang exact same size sa mga branded. Hahaha
    Hehehe! Ok ah.
    Eto yung nahanap ko sa Neuton dati:
    http://www.topgear.com.ph/board/index.php?topic=4661.0
    They have 215/70r16, but 100 lang yung load rating.
    Sobrang bigat kasi ng GS....
    Hay naku!....
    12.9K:foshizzle:
    May 2005
    thanks for the replies.
    i have not seen a tire shop that's selling neuton or nexen.
    most would offer bridgestone or dunlop. another offered west lake and falken which i'm not familiar with.
    akala ko dati marami nagbebenta ng hankook.
    oh well, i'll probably settle for bridgestone later. kaya lang 1 lang kasi kailangan ko sa ngayon.
    hmmm...think think muna...
    Westlake is China-made. That's what my dad is using on the 17s of his Innova. But that's just an Innova, so it's relatively light. Not sure if it can handle the weight of the GS.
    Falken is Japanese. They're about in the same level as Bridgestone or Dunlop, assuming these two are the ones made in Japan. Bridgestone and Dunlop also manufacture out of Thailand.
    Check out the specs of the specific Bridgestone you're getting. On our previous Gen 3 Starex, I used to get Dunlop LM RV 501s with the 98 load rating. I'm not sure if these were crap, but I changed them twice with low mileages on each set due to them getting oblong-ed. Eventually, moving into a different Dunlop with 101 load rating and haven't had the problem since.
    [SIZE="4"]I-try mo yung Bridgestone na "Light Truck" nasa 108 ata yung load rating nun at max psi is 65...Hindi nga lang gaano kagandahan yung tire thread pattern niya pero I thinks OK na yan para sa mga heavy van...Hi-ace nga pala gamit ko and no problem kahit na loaded yung van ko...Dati gamit ko yung wrangler dueler nga ba yun na 96 ata load rating sobrang kakabadtrip oblong agad kahit na mga 15,000Km pa lang tinakbo...[/SIZE]
    Hmmm... Kung Hiace, those are probably 15" tires. There are lots of options for 15"s. Unfortunately, 16"s are a bit harder to come by, especially in Grand Starex size.
    Federal is one tire brand with high load (118 AFAIK) rating due to 3 ply sidewall and 3+2+1 thread ply as well. Mas mataas sa mga branded tires na usually 112 sa AT at 106-108 sa mga HT tires. Mas mura pa ng kunti. Sa 265/70R16 P7,800 ata but Dunlop AT3 is P8,700. Might want to check if meron ganyang brand.
    Quote Originally Posted by jrln View Post
    AT type of tires have higher load rating than HT type tires. So might want to use AT tires. Mas mataas din treadwear rating ng Bridgestone Dueller AT at 500 vs HT na 380 lang ata. So mas matagal din mapudpod for sure.
    Unfortunately, A/T tires can get noisier than H/Ts. Not sure if there's an A/T for 215/70r16 as well. But hey, worth a try if you like the offroad look.
    May 2005
    thanks again for the replies.
    yup, agree with IMm29 that A/T tires are noisier than H/T tires and available variants for 16 tires are harder to find.
    will probably look at Ry Tower's suggestion on Federal. kaya lang parang konti rin lang nagbebenta nito.
    Minerva/Dubshop carry Federal. Try asking Freddie's if they can order you Neuton 225/70r16. Slightly wider but load capacity is the same.
    may goodyear na na pang gs ah
Replacement tires on the GS?
