Results 1 to 20 of 21
    query lang if anyone experienced this, our grx-crdi is just about 2 wks. old just made a long trip to mla (i'm from isabela), going back the aircon just slowed down after about 5 hours of driving humina buga nya. i know that starex aircons are reliable kaya i'm a bit dissapointed ska bago pa sya. before we had the millenium model and the aircon is really good. however the next day after the trip i turn on the aircon again and it works naman just fine so i'm really baffled by this
    is there anyone who can give opinion on this?
    Aug 2003
    Ang nangyari naman sa amin ay nagloloko yung controls ng aircon. Bigla na lang namamatay yung A/C switch tapos pag i-tap ko yung dash board babalik ulit. Parati ding nasisira yung fan control sa dash board. Yung fan speed ng 3 at 2 pareho lang. 3 times ko na ito pina-ayos buti na lang at waranty pa.
    im not really sure if this is the answer to your question, my starex is still the millenium series.. but i had a similar experience with my starex.. well what happend to me was that i noticed that the air coming out of the vents was not that strong as it was when at number one.. so after thinking bout what could be the cause i figured out that the evaporator was probably icing up..previously had the same experience with different car... so wat i did was to turn the compressor switch off and put the fan to number 4.. then i looked under the car and there was so much water coming out of drain hose... after i while i guess all the ice melted so it was working fine again.. which would probably explain as to why your aircon was normal again, the next day...by the way this happend when we were travelling from vigan to manila... just to share another experience of my aircon activities... last december we traveled to mindanao via samar and leyte,, anyways when we got to liloan the aircon totally died on us.. what i noticed was the compressor was still working but no cold air was coming out of the vents.. so i figured there must be a leak in the aircon system.. so after crosing to surigao we added freon and the aircon worked fine again.. a week later i noticed that the aircon was not as cold as it should be and the compressor was not cycling on and off like it should... so i figured the it was running out of freon again... at this time we were in cagayan de oro, going to digos city.. so i figured if we added freon it should be ok until we get back to CDO again.. which comes to the part that i cant explain because from that time until now the aircon is working fine on my starex.. i still havent got it worked on or anything.. except for the adding of freon twice in mindanao...well hope this helps.
    after mo mapa ayos d na ulit nagloko since then? i'm planning to take it back to quezon av branch nila kaya lang nag issue ng no plate no travel ang pnp. ala pa kc plate e, although me authority to operate naman kaya lang baka superseded ng order.
    thanks for sharing your experience. siguro nga nag ice-up ung evaporator that was the case kc when we still have a nissan eagle pick-up. pero ang common denominator natin e, we both make long trips but just the same being a new unit that is not suppose to happen at this time di ba? again thanks for the info, very much appreciated
    Yep. Baka nag-yelo lang. Happened to me in the '03 already. Iniwan kasi ng driver sa max cold yung thermostat.
    kahit ba mainit panahon nag ye-yelo rin un mdyo mainit kasi that time ng nagbyahe kami
hyundai starex
