a bracket needed to be fabricated to support the air filter:
k&n filter finally installed:
Thats a shor ram intake. I have tried to put that kind of system on my E36 before but eventually took it out and returned it to stock. Indeed, it makes a nice growl when you step on the gas, but what I noticed is that there is a considerable drop in power especially during heavy traffic situations, since that engine bay heats up and the air being sucked by the exposed airfilter is of lesser density than that when it has an airbox. But then again its was just mu experience and is highly debatable and has been going on for years, cold air intake vs short ram intake vs drop-in.
what is the correct bulb type for santa fe foglight? h11 or h8 or 881?
Hello po Sir Valskie! Tama po si Sir C190 na its not advisable to change with aftermarket bulbs except kung napundi na ang foglight.
Mas mabuti pa rin palitan with the same type of bulb or if you like, ipa-HID na lang po ninyo tulad nang ginawa namin.![]()
At least di po kami nag-aalala na masusunog yung reflector ng foglamps. Just my two cents po.
Mam LadyRider nai demo ba ni Sir TFR yung alarm system last sunday?
sir medyo confuse lang po ako. may nagpost kasi dito na H8 type ang bulb niya pero pinakabit niya is H11 type na polarg brand. yung iba naman 881 na euroline. so pag hid pakabit ko what type of bulb kaya? nagtanong ako sa mga car accessories iba iba ang sinasabi nila? ty po.
H8 is for sportage foglamps
that time H8 is unavailable- H11 was used with a slight conversion
(Mnmg later changed his polarg with HID)
for Carens .....same with Sportage or SF
881 euroline - Santa Fe foglamps (27w to 80w illuminations- claimed?)
Santa FE HID .............. H27 for foglamps/low and high beams-H7
tama po si Mam LR........better talk with Benjie
*caution- modified foglamps will melts reflectors if used for a long period of time
sa Casa yan....generic lang, medyo mahal
hanap ka na lang sa Banawe para makapili ka ng sizes...
kina Benjie merong all black at satin finish...nasa 3.5k up ang presyo
basta tama yung clamps para sa rack pwede na....
makita mo na rin foglamps bulbs/HID at GT808 alarm with turbo timer(kung crdi engine mo)
try mo rin sa Goldrich
o sa Thule kung high end![]()
