Page 44 of 240 FirstFirst ... 344041424344454647485494144 ... LastLast
Results 861 to 880 of 4793
    Feb 2013
    #861
    found an evgt emblem. ok lang ba ilagay sa crdi natin? or para sa ibang car ito
    Jun 2008
    #862
    Quote Originally Posted by snoot View Post
    IMHO ok lang po. e-vgt naman ang turbo charger ng accent (though I'm not sure about this), pag electronic / ecu controlled ang variable nozzle ng turbo charger then e-vgt yan (my own opinion lang po).
    Feb 2013
    #863
    Quote Originally Posted by weisshorn View Post
    thanks boss weisshorn. it's a US tucson and sta. fe emblem pala originally. good puede ko ikabit bellow the accent emblem
    from Hyundai.com
    The all-new R eVGT (short for Electronic Variable Geometry Turbocharger) dramatically improves power output while allowing it to be more environment-friendly as it is more fuel efficient and releases less harmful emissions.
    The eVGT is an innovative engine technology that electronically monitors exhaust gases to help precisely control the turbine vanes and minimize turbo lag, fuel consumption and boost-threshold.
    Despite being diesel-powered, the R eVGT has been designed to run quietly thanks to the third-generation common rail system developed by Bosch. It also has an internal steel silent timing chain that drives the dual overhead camshaft, making the engine run more efficiently while at the same time making it more durable and easier to maintain.
    Mar 2013
    #864
    just had my longest trip last week end. pangasinan with 18 km/l and tinest ko rin 150kph. wanted to go higher. sinita lang ako ni misis hehe...
    Question lang. at what rev ba most efficient ang accent? 1800? at 150kph nasa 3k na rev.
    Jun 2008
    #865
    Quote Originally Posted by xmcx View Post
    sa mga test for fuel economy usually 80KPH ang average speed regardless of engine rpm. Subukan nyo po sa ganyang speed and post po dito ang fuel consumption para sa kaalaman ng lahat. Thanks
    Apr 2013
    #866
    A/T ba ung 150kph at 3k rpm bro? Kung M/T kaya tapos 6 speed e below 3k kaya?
    Mar 2013
    #867
    Quote Originally Posted by chocomansi View Post
    yes at un. sinubukan ko lang namn in few instances. 80-100 most of the expressway. 4 speed lang kac ung at kaya mataas ang rev. baka mas mababa sa MT
    Mar 2013
    #868
    I want to get a new seat cover. any suggestion po?
    #869
    yung sa pinsan ko (6m/t) nung pumunta kami pa-norte 120-130kph * 1950-2050rpm at * 6th gear. so maybe 150kph sa m/t would be around 2400-2600rpm
    #870
    Quote Originally Posted by 170kphlang View Post
    100kph * 1800rpm
    150kph * 3000rpm
    Assuming linear yung increase ng speed vs rpm, tumatakbo ka na ng 200kph at redline rpm!
    Magugulat na lang siguro yung mga SUVs na oovertakan nito
    Apr 2013
    #871
    so can it go up to 200, watyathink? controllable pa ba at that given momentum? tagal naman kc ung unit ko, 3 months + na ako nagaantay.
    Mar 2013
    #872
    YUp it feel stable at 150. mahirap lang bak amatyambahan ng huli sa express... hahahahaha
    Aug 2010
    #873
    I will be having my 1k PMS tomorrow at marcos hiway (no choice, malapit e). Sana maging maganda experience ko sa kanila.
    Sep 2010
    #874
    Quote Originally Posted by jamesjames View Post
    Sir, pwede paki tanong kung pwede sa kanila magdala sariling oil and filter pag nagpa PMS at kung walang corkage fee? Sa tabi kasi nila, Diamond Motors, pwede ako magdala consumables noon. Iisa lang naman may ari nyan but not sure kung different policy.
    #875
    ^^^Pwedeng magdala ng oil and parts sa kanila pero may 30% corkage fee...
    Apr 2013
    #876
    Hi! Up ko lng po uli!
    I was given a quote for the A/T variant of Accent crdi hatch. I asked an ALL-IN package and agreed to pay in 60 months.
    Here are the numbers:
    20% DP = 173,600
    Monthly Amortization = 17,460.00
    Just wanted to ask your opinions with regards to how reasonable the price is and if I can still do something about it like makipagtawaran sa SA? I can't apply for a bank loan because I do not have an ITR ( tried applying and filing at BIR but they can't categorize where I should fit in - work is freelancing and is being outsourced outside the country).
    Jul 2011
    #877
    20% DP = 173,600
    17,460 x 60 = 1,047,600 + 173,600 = 1,221,200 over 5 years for an 868,000 peso car. Sounds like a really bad deal.
    I got my Livina (AT trim, 908k SRP) last year for 108,000 down and 17,690 monthly for 5 years. And I thought it was already a bad deal.
    Jan 2008
    #878
    Quote Originally Posted by Richardson Chan View Post
    you must also consider the cost of money... the bank will only realize that 400k mark up after 5 years..
    Jul 2011
    #879
    Yeah but if you went the bank financing route, the bank would already be happy to get 14.7k monthly (27% add-on rate over 5 years. Actual quote I got from BDO). So yeah, 17,460 monthly is an effin BAD DEAL.
    Aug 2010
    #880
    Quote Originally Posted by larry0609 View Post
    Okay so I'm done with the 1k PMS sa hyundai marcos highway.
    I was made to choose between mineral, semi and fully synthetic. Sabi ko semi, pero after a while tinawag ulit ako nung SA (name's Jay) and informed me na naubusan sila ng semi hay. Pinili ko nalang muna mineral ulit. They used HGMO, which Jay admitted was just Shell helix. 15w-40 yung nilagay (sana nga). They had a wide lounge where you can see your car being serviced, pero nakatalikod sayo and di mo kita. And yes, pwede magdala ng oil/parts with corkage fee.
    Bago isalang, I asked baket kailangan na 6 liters yung nakalagay sa price list nila na 1k pms. Sabi ko hinde naman 6 liters capacity ng accent, to which he replied, sir mga 5+ po siguro. Mmmkay. Yung natirang 1 liter oil binigay sakin, unopened. Sa madaling salita, 5 liters lang talaga.
    May engine treatment and engine flushing liquid na nakalagay dun sa price list for 1k pms, pero sabi ko ayaw ko ng mga yun. Happy naman ako at tinanggal nya, nakasave ako ng almost 700 (350+ each kasi). Was also offering me engine wash (forgot how much) to which I also declined.
    I observed the performance when I was driving home and wala naman akong naging problems. Bumaba pa nga ata yung fc ko naging 14km/l (7.1l/100km), coming from marcos highway to pasig, or baka placebo effect lang hehe.
    All in all, medyo mixed feelings di ko pa alam kung babalik ako or hanap ng ibang casa for 5k pms.
Hyundai ACCENT Hatch CRDI 1.6
