yung post ko earlier, parts and labor dun.
"1. when my starex GRX was flooded during ondoy and the power steering rack started leaking i brought it to Zafra motors and they had the seal kit for the rack. kung parehas lang ng sa GS maybe they have it.
2. there is also 1 shop at kamias near v.luna. this is where i brought my sorento nagrerepair siya ng hydraulic power steering systems. quite honest, hindi niya in-overhaul yung power steering ng sorento kasi bad lang daw yung viscosity ng fluid kaya matigas. lumambot naman nung napalitan na ng fluid. if he is not honest then he would have insisted on an overhaul di ba? meron siya mga kits for korean cars. here is his contact number >>> 09975018863 ask nyo si Bong Baron. sabihin nyo na lang yung nagpagawa sa kanya ng white sorento few months back ang nag-recommend.
dito ko siya nakita sa olx, he still has his ad active >>> Power steering overhaul and repair For Sale Philippines - Find New and Used Power steering overhaul and repair On OLX"
yung gs ko complete fluid change at 40,000 km. I can confirm that the at fluid, power steering and brake fluids were already of dark color compared to the new fluid. Lalo na yung sa brakes. Ang di lang malayo sa new oil e yung differential oil, green pa din.
sa sorento ko medyo nagtipid ni-postpone ko palitan yung power steering fluid. Ayun after 6 months tumigas yung steering, at may time pa na parang walang power steering parang jeepney yung minamaneho ko. Nung dinala ko dun sa shop na nasa post ko dyan sa taas, yung shop ni bong baron sa kamias, kala ko overhaul na. This was only 2500 km over 40,000 km, so additional 2500km lang. Nung ni-test dun sa shop mababa na daw viscosity nung fluid at madumi na din. As i said earlier lumambot naman ulit after napalitan ng power steering fluid.
i don't remember whatnis the interval in the manual.
Along masangkay street sir. Dami dun sir kaliwat kanan mga shop.
Simplex Industrial Corporation
Thanks for that bro.,- I have a couple of AT rides with mileages at 35KKm[GS] and 45KKm, and so I should seriously consider changing their PS and Brake fluids, too in their next PMS.... Drain and refill should do, right?..
_/_/_/
30.7K _/_/_/_/_/_/_/_/_/_/
Check brakes at change oil pa lang nagawa ko 39,439kms DIY....nagastos 2k+ lang, s brakes linis lang makapal pa pads at b.shoes😁
Sent from my SM-G610Y using Tsikot Forums mobile app
Gamit kong engine oil
Ang GS ko 10seater no major problem till now, mag 6years n.....
Salamat sa input sir cvt
Balak namin mag install ng dashcam sa GS namin...ano highly recommended nyo guys at hm?tia
Sino naka experience na pumanik ng carpark ng shangri la mall ortigas east wing? Di ko makakalimutan yun nagslide kmi pababa kasi di maayos yung cement sa area na yun...buti na lang walang sasakyan sa likod...pagpasok pa lang ng entrance yung area na may uneven surface[emoji1][emoji1]
Sent from my SM-G610Y using Tapatalk
I am using Transcend bro.,- no complaints so far....
I did, with the GS,- and I was mumbling all the way (both going up and going down).... Yup, the tyres at the back screeched at one point,- no significant load at the back so lack of traction....
Good rainy friday afternoon peeps, newbie here and just bought my GS TCI MT 10 seater variant 2 weeks ago. Problem started monday morning cold start. HARD STARTING issue barely 273 reading on my ODO. it takes 3 attempt before the engine start and with a slight press on the gas pedal. Come tuesday still the same now with longer duration, 4 attempts or 4 pihit ng susi bago na start, still with a slight press o apak on the gas pedal. Eventually causing/producing white smoke upon engine start.
Bought to casa thursday, though still experience the same prob when engine started that day. Same white smoke and slowly nawawala as engine temp goes high. HARD start on encounters during cold start (overnight parked). During continuous use or start Off/On or warm engine, no prob one click not even stepping on the gas pedal.
Casa recommend overnight observation so they asked me to leave my unit and will try the start up process 1st thing in the morning and will provide me updates. The next day (today) updates were provided. it was indeed hard starting. Common lang daw un during COLD start. Need to daw dapat turn the keys from on to ignition 3 times with longer wait time before switching to full start.
Is this true? I hope someone can enlighten me on this..TIA
read the owners manual. there is a mention there how to start the engine. glow plug indicator must disappear before you start the engine.
Hi Guys,
new TCI owner din po ako i just recently purchased GS 2.5 TCI M/T ang dami ko natutunan sa thread na ito nagbasa basa muna ako dito bago ko talagang bilhin ang aming "Stariray". as per sa mga inputs ng ibang TCI owners grabe pala ang laki ng patong ng mga casa sa kanilang mga services and parts. Since bago lang po ang GS namin (300km) would it be necessary talaga na sa Casa ang PMS?
OT: Any group po ba ng GS around South area po?
Maraming salamat po!
