Originally Posted by
dr. d
does it have a (red, usually) pilot light that glows strong when a key is pressed?
if it does not glow strongly, then there's something wrong with the remote.
clean the battery and contacts well. clean the keys also (not the buttons outside, but the opposing surfaces inside.). if it still does not glow strongly, your unit might be beyond repair to us mortals.
and, believe it or not, check battery polarity.
if the system is an aftermarket and not factory, you might be able to get replacement remote. ask around from dealers.
or, you might considering replacing the entire system. it should not cost too much. less than 5K siguro.
if the alarm is factory, you'll probably be better off by having an ex-factory system installed. it'll probably be easier and cheaper, than sourcing a replacement remote.
or, you could just do away with the entire thing, and do the good old days of completely manual lock and unlock.
good luck.
