Page 133 of 160 FirstFirst ... 3383123129130131132133134135136137143 ... LastLast
Results 2,641 to 2,660 of 8077
    Jul 2003
    Napalitan ko easy ang cabin filters. Guide yun russian youtube videos.
    First korean car too, mas tahimik idling vs montero.
    Balak ko sana diy fuel filter change pero mukha not that easy. Hanap muna ako nun 3-leg filter wrench katulad sa video.
    Power is good. Might be a tad better than my montero vgt kahit 3000kg body ang van.
    Goodluck to me sa napili kung unit
    Thanks sa mga share.
    Apr 2012
    Quote Originally Posted by kurt View Post
    GS performance is better than MS
    Sent from my ASUS_T00J using Tsikot Forums mobile app
    Jul 2003
    Kamusta long term effects ng egr blank sa GS.
    Backread circa 2013 may tsikoteers nag egr blanking. Wala nasira sensors or anuman? Hindi nabutas yun plate?
    Sep 2014
    Sent from my SM-G900F using Tsikot Forums mobile app
    Sep 2014
    Up
    Share ko lang.
    Zumi Duo Camera for my GS. Currently taking power from the front power plug. Which is one of my rants sa GS. Iisa ang power plug amp. Buti pa yung 2008 everest namin meron sa likod.
    I bought a hardwire kit for this dash cam. Maybe after the car turns a year old tsaka ko ikabit.
    Apr 2012
    Up
    Share ko lang.
    Remove the cigar lighter. Pwede pa power socket yon
    Sent from my LG-H818 using Tapatalk
    This is the only one that i have. By the looks of it, there's supposed to be another power plug below. But its blocked out.
    Nov 2007
    Yes 2 ang power plug sa harap.
    Im planning to have this usb outlet installed at the 3rd row cup holders
    I could have sworn that the outlet below the cupholder is blanked out. Damn HARI. Pati ba naman ito inalis pa. Tsk tsk.
    Plano ko din yan. After na mag one year old nitong GS.
    Aug 2003
    Nye! Pati yun tinanggal na ng HARI. Anyway, here's what the stock power outlet in front looks like:
    I installed an additional power outlet in the rear cargo bay of our GS. You can see it here: 2008 Hyundai Starex (Gen. 4)
    Quote Originally Posted by Automahn View Post
    Sir saan mo tinap yung power outlet mo sa likod?
    Aug 2003
    Sa fuse box sa harap under the dashboard. Nagpagapang ako ng medyo makapal na wire all the way from the rear papunta sa under-dash fuse box. Gusto ko kasi pag nakaswitch sa ON yung ignition, saka lang gagana yung power outlet para kahit maiwang nakasaksak yung chinacharge, di madedrain yung battery ng sasakyan.
    I see. Malamang gumamit ka ng "fuse tap" tulad nito.
    Incidentally yan ang exact type na para sa GS. By the way ilang gauge yung wire na ginamit mo?
    Micro ang size ng fuses para sa GS. Its the exact pic na pinost ko
    Nov 2007
    Thanks sa replies. Mukhangdi ko kaya i-DIY ang paglagay ng usb outlet. Pagawa ko kana lang sa ACA
    Nov 2007
    One important tip that i got from the FB group. Kung matigas buksan ang sliding doors, most likely dumidikit ang stock rubber stoppers that are on the top edge of the doors to the metal.
    Need to place new rubbers by using rubber stoppers for chairs from ace hardware, diy shop etc. 25 pesos lang.
    Madali na sya buksan. Hindi na mapuputol ang door handle. Mine broke off early this year.
    Here's what i bought from ace. Size 3/4. Need to trim a bit para flush fit over the old stopper
    Apr 2012
    Quote Originally Posted by JJB View Post
    San banda ikakabit yan?
    Sent from my SM-J730G using Tapatalk
    Nov 2007
    May existing rubber na sa top part ng sliding door. Trim mo lang yung new rubber before placing it flush on the old one
    Jul 2003
    Yan mod ba is to prevent the door sticking? Ok naman oag bukas ng sliding pero maganda kung makatulong iton mod ma preserve yun mechanism.
    Ang hina palan ng foglights. 27watts parang Drl.
