Results 5,431 to 5,440 of 8077
Certified MB Addict
- Apr 2007
- 2,284
May 12th, 2014 01:28 PM #5431
May 12th, 2014 01:34 PM #5432
In that case its safe to say na ok pa din yung 102 load index sa 225 or 235 in our gs
Posted via Tsikot Mobile App
May 12th, 2014 05:34 PM #5433
On the brochure, GS's curb weight is 2,204 kgs and gross weight is 2,770 kgs.
With these load indices:
Load Index Chart
So, parked it's 2,204 kgs / 4 tires is 551 kg per tire. So at the very least the tire should have a Load index of 88 (560 kgs).
Say you usually have a driver and a passenger weighing about 150 lbs each (136 kg total), then it's 2,340 kgs or 585 kg per tire. At least 90 load index.
If you have a total of 9 occupants at say 150 lbs average (614 kg total), it's about 705 kg per tire or at least 96 load index.
I agree with fast lane, 102 should be safe enough even if loaded. For my 18s, I had been on 235/50 with a 97 load index for over 2.5 years. Sure it wasn't fully laden most of the time -- average of 2,400 kgs half of the time, or much less for others. Treadwear was the issue for the tire change though. I'm now using 101 load index on 235/50r18.
May 12th, 2014 11:45 PM #5434
May 13th, 2014 03:50 PM #5435
Hi bratski,
Now using Sailun Atrezzo ZS+. Pumped up to 45 psi cold all around.
How about you, how much air do you have in your 18s? Oh, and where did you source your 18s?
May 13th, 2014 04:39 PM #5436
How much did you get those sailun tires sir? I bought mine (nankang sp5) for around 5800 each at marikina. I have these tires for a little over a year now. Same tire size as yours 235/50-18. Im a little worried about the 97 load rating as i sometimes load my starex whenever i go out of town. I usually pump in 38 psi front and 40psi at the back. Honestly ride comfort suffered from the stock 16s. Im currently at 37psi all around to minimize bounciness hehe.
Posted via Tsikot Mobile AppLast edited by bratski; May 13th, 2014 at 04:43 PM.
May 13th, 2014 05:04 PM #5437
May 13th, 2014 10:00 PM #5438
May 14th, 2014 12:11 AM #5439
Any one here know the differences of the following Starex variants of Hancars?
CVX Luxury
CVX Lux with VDC
CVX Lux with SRF
CVX Premium with SRF and VDC
HVX
Posted via Tsikot Mobile AppSignature
May 14th, 2014 03:31 PM #5440
Freddie's Tire Supply along Evangelista. Not sure if they have 55 series though. You can ask them (888-0394) na lang. Ok naman ang 50 series sa akin, it's slightly bigger than the Dunlop LM703 they replaced. What I don't like is the look of the 55 series on our 6 spoke rim design.
A 70/30 water to coolant mix may improve cooling efficiency but that's at the cost of less...
Coolant...
