Results 1 to 8 of 8
    Oct 2009
    mga sir tanong ko po..whenever i step on the brake * more than 60 kph ang takbo may nararamdaman akong wigle. pero once nag reach na ng 60 or less ang kph ko. wala naman. basta less than 60 ang takbo ko then nagbrake ako walang wigle. ano kaya ang problem nito? 4 months ago nagpalit ako ng pads ok naman it was only 1 month ago lumabas yung wigle.
    Oct 2009
    suspension? or tires? pag racing tires kasi madulas :D
    Mar 2005
    could also be warped disc brake. had the same problem with my small body corolla before. ni-resurface lang yung disks, ok na.
    pwedeng simpleng hindi balanced na gulong to as complicated as warped discs o kaya sirang balljoints, tie rods or loose bearings. pacheck mo sa mga underchassis/alignment shops. free naman usually ang checkup/estimate.
    Oct 2009
    Ako din ganyan eh. Pero mga 130 km/h nag wiwigle kapag nag bbrake. Bagong kabit lang ang rotors ko gamit ko Crossdrilled/slotted rotors at bagong pads. I use Neova tires. ano kaya prob? TIA
    Oct 2009
    rotor is the culprit
    May 2007
    Front rotor warped. Need to replace.
    Jan 2011
    check mu tie rod in o ball joins..these are usually the most common culprit...ito plagi experience ko dati..
wiggle during braking
