Results 1 to 8 of 8
- Oct 2009
- 1
October 18th, 2009 03:49 PM #1mga sir tanong ko po..whenever i step on the brake * more than 60 kph ang takbo may nararamdaman akong wigle. pero once nag reach na ng 60 or less ang kph ko. wala naman. basta less than 60 ang takbo ko then nagbrake ako walang wigle. ano kaya ang problem nito? 4 months ago nagpalit ako ng pads ok naman it was only 1 month ago lumabas yung wigle.
- Oct 2009
- 34
- Mar 2005
- 233
October 19th, 2009 10:01 AM #3could also be warped disc brake. had the same problem with my small body corolla before. ni-resurface lang yung disks, ok na.
Tsikot Member Rank 3
- Nov 2002
- 1,757
October 19th, 2009 10:51 AM #4pwedeng simpleng hindi balanced na gulong to as complicated as warped discs o kaya sirang balljoints, tie rods or loose bearings. pacheck mo sa mga underchassis/alignment shops. free naman usually ang checkup/estimate.
October 22nd, 2009 07:05 PM #5
Ako din ganyan eh. Pero mga 130 km/h nag wiwigle kapag nag bbrake. Bagong kabit lang ang rotors ko gamit ko Crossdrilled/slotted rotors at bagong pads. I use Neova tires. ano kaya prob? TIA
- Oct 2009
- 15
- Jan 2011
- 2
January 15th, 2011 04:59 PM #8check mu tie rod in o ball joins..these are usually the most common culprit...ito plagi experience ko dati..
Monk-owned R53
