Results 1 to 7 of 7
- Aug 2007
- 41
June 29th, 2008 11:18 PM #1sirs,
sirs my car is civic vti 2k model..the thing is most people say na sakit nga daw ng ek's yung water getting inside the trunk..sabi nila maglagay ng epoxy or something..
susubukan ko sana kahapon pero hindi pala ganun kasimple..
baka po may kilala kayo na gumugawa nito na permanently maayos sya..and magkano..mejo hassle kase..lalo ngaun rainy season..
thanks in advance sirs..
June 30th, 2008 01:27 AM #2
kapag pinasok ang tubig sa trunk, check the rubber around the trunk or the the trunk opening holes where the spare tire located. Somewhere is not at place correctly or tear on the rubber seal or back window may have leak or there is hole in the body. Trace where the water came from sometimes it leave's a trail where water has been leaking in.
June 30th, 2008 05:39 AM #3
does your car have a spoiler? water might be coming from the holes on the spoiler.
- Aug 2007
- 41
June 30th, 2008 10:09 AM #4i checked it the other day and the water is coming form the tail lights and the antenna..as ive read sa ibang thread ito daw yung madalas..and true enough dhl dito nga..plus parang meron din nanggaling sa gap between rear bumper and driver side rear fender..i dont know kung meron pang iba..
baka kase mababoy ko lang pag ako gumawa kaya gusto sana maghanap ng gumagawa nito..since common problem nmn to among EKs baka meron ng mga gumagawa nito to permanently fix this problem..
thanks sir sa mga inputs so far..
by the way wala po ako spoiler..
June 30th, 2008 10:12 AM #5
pwede rin galing sa tail lights-body gap pumapasok ang tubig bro. silicone sealant lang naman katapat niyan. that's better than epoxy bro & less messier too
June 30th, 2008 10:13 AM #6
pa re-seal mo na lang yun taillights mo...meron nabibili na long kind of putty specifically for tailights sealing...ganun nilagay sa akin dati yun nagpalit ako ng aftermarket tailights...
June 30th, 2008 10:44 AM #7
sa akin meron din, pero intermittent ang pag babasa, at first akala ko yung mga kinakarga kong tubig minsan natatapon. sa lefts side sa akin (EK) pwede nga galing sa antena.
ito ang i checheck ko. maraming salamat sa inputs
If Mitsu prices this above 1.4M then buyers will flock to either the Corolla Cross hybrid, the...
Mitsubishi Xforce
