Results 11 to 15 of 15
- Aug 2005
- 205
July 22nd, 2009 07:56 PM #12
check mong maigi kung merong mga leak sa hose and connections , sa radiator at water pump ( meron itong weep hole dito lalabas ang tubig pag sira na ang oring ).
- Jul 2009
- 31
July 26th, 2009 04:39 PM #13Sir madali makita pag may leak sa bandang takip ng radiator medyo may kalawang kang makikita. Pero eto lang ah, kasi vtec 97 ang akin dati ganyan din ang naging sakit, dinala ko sa radiator shop hinayaan muna lumamig ang engine tapos tinanggal ang radiator cap pina-start bumulwak ang tubig palabas (normal circulation kasi ng tubig dapat papasok sa radiator to engine kaya di dapat bubulwak palabas). Tapos binalik ang radiator cap inobserve at namamaga ang radiator hose. Most likely ang diagnosis dito ay problema sa cylinder head.
- Jul 2009
- 31
July 26th, 2009 04:49 PM #14additional lang sir, di rin nag-ooverheat ang vtec ku noon. try mo gawin yung sinabi ko sir garantisado yun. baka gasket lang din sa cylinder head ang problema ng vtec mo. puede rin gawin mo after mo mapaoverhaul ng radiator para mas sigurado ka
- Aug 2006
- 9
July 26th, 2009 05:02 PM #15Again thanks for all the replies. Diagnosis was to replace the radiator cap, had the radiator flushed din.. Till now wala pa naman bawas ang reserve. Hope that's all...wala ding pressure from radiator upon starting the engine and even accelerating... By the way water pump is replaced na last year sabay timing belt.
unless sira the lock, most car door locks are designed to make it more difficult for you to lock...
