Good day po. I have this issue with my 2009 Honda Jazz GE that whenever I'm using the headlights, I noticed that the aircon knobs, side of AT shift stick, and the power window buttons are getting warm to the touch. Not excessively hot but still noticeably warm. At first i thought it was randomly happening but recently, it's been more consistent to occur at night when I'm using the headlights.
I checked to see if my theory's correct by turning on the HL for around 5 mins and I was correct. Do you know sir the problem with this or is this even a problem and basically normal? First time to own an automatic.
By the way, the right headlight sometimes doesn't lit up. It usually takes a while unlike the left side. I'm thinking that it's related.
My plan is to try the following:
1. Replace the headlight bulbs with the same type of halogen bulb, check if the warming issue still occurs.
2. If 1 fails, replace with LED since it has lower wattage requirements so it shouldn't warm up anymore
What do you suggest I do sir? Thank you.
