Results 1 to 10 of 10
    Hi sirs,
    I've recently grown fond of using the car to watch movies. It's pretty relaxing in there when you're just parked somewhere.
    I use my trusty PSP and just hookup the audio to the aux of the car. Of course i turn off the engine cause i don't want to waste fuel while watching a movie I just leave the key there so i can still use the speakers..
    I've been wondering if there are any problems with doing this like 2x a week..
    (I'm concerned about the battery discharging etc.. )
    thanks mga sirs
    No problem really as long as your battery and electrical system are in good order. Just don't play at max volume.
    You can see how many minutes of reserve capacity your battery has, it's printed on top of the battery case. That is the amount of time the car can run with all the accessories on should a total failure of the alternator occur.
    May 2007
    Correct!:chopper:
    pero huwag kumpiyansa.
    baka hindi na mag start ang engine mo due to drained out battery.
    Jan 2009
    OO NGA... MAG EARPHONES KA NLANG PARA SURE...
    thanks mga sirs.
    *sohc_teejay, *s_quilicot yeah, kaso pano naman ung kasama ko hehe.. mas masarap kasi mag hangout at manood sa car hehe ^^ walang storbo
    Quote Originally Posted by jaysondin87 View Post
    thanks mga sirs.
    bili ka ng voltmeter na pwede lagay don sa may lighter para mamonitor mo yung battery mo kung kelan mo na kelangan mag start ulit ng kotse para ma recharge. hehe.
    yep, bili ka ng plug-in voltmeter nalang. if your normal battery is 12.6-12.8 volts. don't let it drop 12.3.
    but for a worn-out battery. voltmeter are insignificant. kahit naka 12.8 volts yan after engine was running and turned off, it could still NOT start on you when you click the next time.
    Under normal conditions,- kayang-kaya iyan ng iyong battery. Wala namang subwoofer, di ba?....
    7303:soda:
    *rion,*flakez cool idea! cge cge biili ako! pero hehe cguro nde ko na lang aabusuhin ang panonood ng movie dun
    *CVT, yep sir wala pong subs. all stock! takot ata ako mavoid ang warranty!
    Thanks uli sirs
using audio system with engine off
