Merry Christmas mga master! Ask ko lng kng saan ako pwede mag paayos ng car ko, kasi ang lakas ng tagas ng langis. i had it repair sa mekaniko and pinabili pa ako ng gasket and oil seal but nothing happened andyan prn ung tagas. pa help nmn kng sino expert d2 ng mga ganitong problema and not much expensive. Im using '96 Honda Vtec. TIA
palpal yung mekaniko niyo boss, san po ba ang location niyo. if your from south i recommend Prens Alabang, look fo Jec, same model kotse natin. I can vouch for this mechanic. HTH
ung tagas e malapit sa front left wheel. Im thingking before na its the ATF pero itim ung langis nya so its confirm na engine oil ung tumutulo. Im from QC, sino ba malapit d2 at ma recommend nu?
Hi Neewbie here.... I sugget you check out first where the leak is coming from... I had the same problem with a 97 VTi.. I had to replace the oil strainer gasket, oil pan gasket, head gasket along with the screws of the the head cover...... I think its a common problem since we got a car that is more than 10 years old....
I had GTS car care at congressional ave. do the installation but I bought the parts at Honda...
kung tumutulo na delikado na po yan, kung nagpapawis pwede pa pagpaliban. try mo sa mga servitek or gas station. madali naman makita kung saan ang leak pag nakataas na ang kotse. kung magaling ang mekaniko mas madali ma didiagnose ang auto mo.
kung wala kang alam na repair shops try mo ipa diagnose in 2 or 3 shops para may idea ka kung sino ang tama sa kanila.
simple lang sir.. lahat ng pinalitan ng mekaniko mo mali at hindi niya nahuli yung tunay na sira. For leaks, gaskets lang naman pwede mong tingan tsaka loose bolts.. tama mga brother natin dito, hanapin mo muna kung sa galing yung leak.. mas maganda ikaw na mismo maghanap tapos yun ang ituro mo sa mekaniko para mapalitan ang dapat palitan..
