Results 1 to 10 of 18
- Dec 2008
- 12
May 24th, 2009 01:10 PM #1need help...sir ano kaya problema ng oto ko..ung RPM kc hindi pumipirmi sa 1000 khit d tumatakbo ang sasakyan ko...tapos parang umuugong ang tunog ng makina...nagpalit n ko ng ignition coil...carburator type ang honda ko...help me pls.
- Apr 2008
- 537
May 24th, 2009 04:05 PM #3
confi05,
please identify your vehicle completely. state model and date of manufacture, whether the car is a frankenstein (assembled of different components), repair history, last thing done to it, mileage and telltale signs and symptoms. the frequency, time of day, duration when all these symptoms occur. check the basics first using your owner's manual.
jick
certified auto
guam
- Dec 2008
- 12
May 24th, 2009 04:46 PM #4kahit hindi ako naka aircon nagtataas baba pa rin ang RPM ng oto ko...ang oto ko is honda civic 94 LX...ngayon lang e2 nagyari sa oto ko, dati ang ganda ng takbo walang problema...
May 24th, 2009 06:05 PM #5
confi05,
the fluctuating engine speed is called hunting. if your car is carbureted, chances are either your idle speed adjustment is too low, your intake system has a vacuum leak or your PCV valve is stuck open. you may also check your carburetor for gum and varnish buildup. if your carburetor is dusted from absence of or has dirty air filter, you might consider cleaning the carburetor with a "carburetor spray cleaner". follow the instructions on the can. but try not to run the engine while spraying, in some cases the engine caught fire from stray high voltage from the ignition system. clean the carb throat as well as the linkages outside the carburetor. one spray can should be enough.
jick
guam community college
- May 2008
- 12
May 24th, 2009 09:23 PM #6Do yourself a favor and go to Kamias/Kamuning road in QC.
Maraming Carb cleaning/tuning experts dun.
May 24th, 2009 09:51 PM #7
go to A & M Carburetor specialist sa kamuning, hanapin mo si elmer. From edsa, nasa left side mo yun. dapat maaga ka, 8 am, kasi mabilis mapuno yung lugar.
May 25th, 2009 03:01 AM #8
baka nga cleaning lang yan, nangyari na yan sa kotse ng tito ko. test mo muna un. mura lang naman palinis.
- Dec 2008
- 12
May 25th, 2009 08:52 AM #9thanks to all of your advise.... bka nga carburetor lang.. kya ipapalinis ko na muna... mga magkano kya ang "carburetor spray cleaner"?
May 25th, 2009 10:45 AM #10
bro mas maganda palinis mo na muna gaya ng sabi nila punta ka sa kamuning maraming shop doon na gumagawa ng carburator,
Wag ka nang bumili ng carb cleaner spray kasi yung dumi pag spray mo mawawala ng sa paningin mo pero tinulak mo lang sa loob ang mga dumi lalo mo lang pinapasok, baka lalong magkaproblema ang ride mo, gusto mo ba yun?
considering a Ferrari has an average price range of 20-25M. multiply that with 666 units sold then...
Car Sales Data (2024)
