Results 11 to 18 of 18
- Dec 2008
- 12
May 26th, 2009 03:24 PM #11bumili ko ng carburetor spray cleaner pero parang wlang nabago...bkit ganon? parang naghihingalo p rin ung oto ko....
- Feb 2007
- 89
July 13th, 2009 12:11 PM #12Hi to all,
This is also happening to my friends 1997 Honda Civic when the car is in "D" and "P". What could be causing this?
I told him to bring his car to a shop and have the car "throttle body" cleaned by a mechanic but I'm not really sure if it can fix the problem
July 13th, 2009 12:52 PM #13
^pwede rin iyan ang cause. pero pa-sabay mo na din palinis sa kanya ang iacv ng civic niya. ganyan din sa akin dati. he could do it diy style or have it serviced at speedyfix or forcedspeed if he lives in the north (or any other reputable shops in his area)
July 13th, 2009 01:17 PM #14
- Oct 2003
- 326
July 13th, 2009 09:03 PM #15
- Jan 2008
- 19
August 7th, 2009 04:45 PM #16hi,
i am not sure if anyone experiences this same problem. i have a 97 city mt.. my rpm is okay, i say 90% of the time.. kaya lang, there are instances wherein babagsak nalang ung rpm ko ng sobrang baba to the point na halos mamamatay na makina ko, siguro nasa 100rpm lang..this only last for about a few seconds, probably 10-15 seconds lang... it does not happen all the time.. it happens whether naka aircon ako or not..
for example, tumatakbo lang ako ng normal then i come to a full stop, that's the time na bigla nalang babagsak rpm ko.. so minsan kapag bumper to bumper or pag magbabayad ng toll... do you guys have an idea on this case? i don't experience this everyday... may mga certain times lang talaga.. thanks!ü
August 7th, 2009 04:55 PM #17
same prob with my old esi.. i just had my carburetor serviced ayun ok na siya
- May 2009
- 1
August 10th, 2009 08:30 PM #18i hope this could help you guys, here are some additional information.
if the idle is low your throttle body need some clean up or you can adjust the screw for the idle to goes up.
if the idling is not stable check the spark plugs.
Xiaomi E-Car
