Results 1 to 16 of 16
    Apr 2010
    Any advice in timing belt replacement?
    Things to consider and things na gagawin ne necessary ipagawa upon timing belt replacement.
    Need inputs also sa brand ng parts na gagamitin or should i use OEM sa lahat na parts?
    Need input reputable and cheap store to purchase the said parts.
    Unit: Civic ESI '94
    More power guy's,long live tsikot.com
    Tia,
    Aug 2008
    replace the water pump na rin kung may budget para isang labor na lang...
    replace na din tensioner at idler...minsan kasi mga mekaniko di pinapalitan yun laging timing belt lang
    Jan 2008
    dont forget the cam shaft and crank shaft oil seal..
    Sep 2009
    sir try mo sa fertes, may OEM sila sa mga parts ng car mo mura pa.
    Jul 2013
    mga sir kaylangan ba pag nagpalit k ng timing belt need din palitan yung ibang components like tensioner......etc?thanks po
    Jul 2013
    Quote Originally Posted by code7 View Post
    Unit: Civic ESI '94
    Tia,
    In replacing TIMING BELT, you should consider replacing these parts too:
    - OEM Camshaft seal
    - OEM Crankshaft Seal (front or pulley side)
    - Water Pump (GMB Brand)
    - Tensioner Bearing (KOYO Brand)
    - ENGINE OIL
    - COOLANT
    - and of course.. OEM Timing Belt.
    If needed, replace the Valve Cover Gasket and Spark Plug Seal.
    Sep 2013
    Quote Originally Posted by wallyvelasco View Post
    - OEM Camshaft seal
    - ENGINE OIL
    - COOLANT
    Sir mga magkano po gagastusin lahat lahat ?
    - OEM Camshaft seal
    - ENGINE OIL
    - COOLANT
    This is pretty much spot on. Labor for my toyota was around 2500 or so a year ago. But I also replaced the coolant, engine oil, oil filter, air filter, fanbelts para isang baklasan na lang
    Sep 2013
    buti na lang nabasa ko to.planning to replace timing belt.sir san kayo or kanino mekaniko nagpapagawa to replace timing belt?painstruct n lng po kung saan atska baka may contact no. salamat po
    Oct 2013
    Sir may kilala ako ok gumawa at hindi ka tatagain s presyo.. kaya lang meycauayan.. mang ramon! Lahat ginagawa nila from latero, makina, simpleng susian.. one stop shop..
    Sent from my GT-I8552 using Tsikot Car Forums mobile app
    Beep Beep! School Bus! Beep Beep! School Bus!
    Sep 2013
    salamat sir pero mejo malayo sa akin qc area lang po sana
    Nov 2013
    just a noob question mga sir.. how would you know na kelangan na palitan ang timing belt? Thanks in advance tsikoters!
    Jan 2008
    Quote Originally Posted by Monshar Tuaņo View Post
    visual inspection of the belt for signs of wear and tear or based on the manufacturer's recommended replacement interval referring to the number of kilometers as indicated in the car's odometer.
    if there are leaks in you front camshaft seals or crankshaft seals, there is a possibility that your timing belt get contaminated by oil. oil can damage belts resulting to premature breakage.
Things to consider during timing belt replacement
