Originally Posted by
wezz_zzew
Meron ng ganitong issue (CVT) dun sa isang thread ah (Second Gen Honda Jazz/Fit). Anyway, I'll share my wide experience on my GD-CVT.
Twice na ako nagpalit ng tranny, first time ko naramdaman yung problema during our way home from Antipolo. While traversing the highway, bigla na lang nag blink yung "D" ko and then nararamdaman ko na humina yung hatak nya. Imagine, nasa 5000rpm ko pero ang takbo ko 30kph. I've decided to pull over in one of the gasoline station to check the manual while letting the engine rest. Nung start ko na, mejo bumalik sa normal condition so ang akala ko okay na but nag research pa din ako sa net ng preventive action and according to some GD owners, you just need to add/replace the CVT fluid, which I did. Almost 1 month wala ako nararamdaman na problema then suddenly, bigla na lang hindi gumana tranny. As in wala talagang abante, pero may reverse. I did everything to resolve the issue to wit; change oil, spark plugs, brake fluids and CVTF but to no avail. Dun ko lang nalaman na talagang wala na pag-asa kaya I've decided to replace the whole tranny.
Second time, ganun din. Nag blink yung "D" and then nawawala din pag shut-off then start. After a week, ayun! itinirik ako sa gitna ng macapagal and buti na lang naramdaman ko dahil nasa third lane ako pero naitabi ko pa din sa gilid habang naka umaandar pa siya.
Suggestion ko lang sayo. Wag ka lalabas ng bahay with less the 5-10k ang dalang pera dahil worse na pwde mangyari talaga sayo is itirik ka sa gitna at ma-tow and matiketan pa. Another thing, stop using the 7 speed mode dahil yun ang malakas makasira. Feeling mo nasa 2fast 2furious ka ba? He,he.
