Results 1 to 15 of 15
    Dec 2008
    I'd like to know from you guys regarding this problem.
    My friend also has a 97 Civic Lxi and he's concerned about the abnormal rising of temperature of his car. We both checked the radiator, have it drained and cleaned and we also checked the hoses and found no leaks. According to him, he often checked and filled the radiator with water before he drives. It seems all are just fine.
    We've tried to observe it and in just an hour of driving or maybe less, the temp increased gradually, but dropped down to normal temp a minute after and then keep rising up and dropping down again. I haven't experienced such problem in my Civic, so I have no idea what it regarded for.
    I'd appreciate your cents bros. Thanks!
    have you checked the radiator cap if it's still in good condition or if the rubber has gotten brittle and developed cracks?
    Dec 2008
    Yup, we've checked the rubber cap and rubbers. All in good condition.
    without leaks? water pump failure and radiator thermostat malfunction and/or stuck up are some of the causes. also the electricals and the thermo sending unit. HTH
    Quote Originally Posted by nOnOize View Post
    Am I correct in my understanding that he fills the radiator with water every time he uses the car? If it is then there could be a leak at high pressure,- check out the wafer pump.
    Also, what's the level of the thermostat, when you said that the "temperature is abnormally rising"?
    7202:bruce_lee:
    Nov 2007
    try mo din i check ang hose na nakalagay sa coolant sir baka yung hose na papuntang coolant e natangal or hindi masyado naka ayos, pwedeng hindi mag circulate pag ganun
    most common problem diyan yung rad fan switch ( thermoswitch sa may thermostat housing)
    Nov 2007
    He said he fills up his radiator with water every time he drives .
    Then it's suggestive of a leak, isn't it? Because n my case, I never find the coolant level in the radiator decreasing each time I check. Parang hindi normal ang palaging nagto-top-up ng water.
    malamang leak somewhere, when you say clean pinabuksan mo ba sa radiator repair shop or nag drain ka lang? baka din kasi barado na yung ibang butas at baka din may pinhole leak, hirap hanapin nito.
    check mo rin yung radiator fan and the thermoswitch.
    one possibility ... radiator fan motor have worn-out carbon, may or may not rotate at times, low-power rotation ... causes similar overheating symptoms, overpressure will cause rad cap to release some water
    on way to find a tiny leak is to listen for it carefully when the hot engine has just been turned off ... or feel around for some invisible steam being released (but this could be painful)
    Dec 2008
    Thanks to all your replies Bros. All were noted and helped rectify the problem. We've found out there was a small leak from one of the rubber hoses as it wasn't tightened enough. Somehow it was releasing steam causing the gradual losing of water. Thanks for the help.
Temperature abnormally rising.
