Results 1 to 9 of 9
- Jun 2010
- 27
June 6th, 2010 03:46 AM #1mga bro,pahelp sa steering ng auto ko..
pang pumalo ng 80kph..nag wiwiggle..
ung right front wheel lang..nagtataka ako bago gulong nya.
bago bushings.nag wheel balance.ok na sya lahat..
pero pag nag 80kph..may wiggle pa din..
ano kaya problem nito sir??ung mag s pla 17's tas ung tire ok naman..bago accelera..para makapal ung tire..pero may wiggle pa din..ano kaya prob nito??
auto ko:honda civic 96 vti..(converted to SIR)
help me plsss...
- Nov 2009
- 456
June 6th, 2010 12:11 PM #2Raise the front tires (with the steering locked) then hold the edges of the right wheel with your hands at 9:00 and 3:00 position. Try to wiggle it. If it wiggles, then you have a worn out tie rod. Now hold the wheel at 12:00 and 6:00 position. If it wiggles, then the ball joints needs to be attended to.
Do this to the left front wheel also.
- Jun 2010
- 27
June 8th, 2010 07:51 PM #3thank you sir..try ko bukas..ngayon lang kasi ako nkapagonline let e..
thank you let sir..post aq let d2 pag d pa naayos..
- Jun 2010
- 27
June 8th, 2010 08:15 PM #5kakatapos lang wheel balance to..
bago lahat ng bushing,suspension arm,tires.
kaso pag nag 80 nag wiwiggle..
try ko ung cnabi ni cvicvti..
kasi lahat napaaus q na.pero nag wiwiggle pa din..
bukas subukan ko..
- Jun 2010
- 27
June 8th, 2010 08:17 PM #6civicvti,sir bago nga pala tire rod nito..
check ko ung ball joints..pero tingin ko bago din ata e..
- Nov 2009
- 456
June 8th, 2010 11:54 PM #7It could be any suspension part (tie rod, ball joint, stabilizer linkage). Have it checked by a reputable shop before venturing out into the highways.
- Jan 2008
- 4,726
June 9th, 2010 12:33 AM #8how about alignment??
try to borrow a different set of rims and tires (preferably stock tires of civic) then test
- Jun 2010
- 27
June 9th, 2010 03:34 PM #9mga sir.ttry ko palang tom..
mejo busy pa..
post aq d2 pag may prob pa din..
thank you..
Xiaomi E-Car
