Results 1 to 4 of 4
- Nov 2010
- 14
November 17th, 2010 05:43 PM #1mga kapatid what's the best and right way ng radiator flushing at refilling for civic ek? just diy tips lang mga kapatid....thanks
November 19th, 2010 02:42 PM #2
Sir, ang gawain ko po every 3months nag drain po ako ng radiator tapos ang gamit kong tubig e distilled water para hindi agad mag corrosion yunlng po tip ko.... kahit hnd kana coolant ok lng po un....
November 19th, 2010 03:12 PM #3
ayaw mo mag try ng Lavramon? one time gastos lang ito para hindi ka na palit ng palit ng tubig.
- May 2009
- 11
November 25th, 2010 04:17 PM #4DIY?
tanggalin mo yung malaking bypass hose from radiator to engine, ang tatangalin mong part is ung nasa engine end ha... then running hose place it sa oepner ng radiator cap para nag rerefill then ung tubig labas sa engine, ganun ang flushing hanggang luminaw ung tubig... then kapag ok na, drain mo na lahat ng h20 then buy coolant i-mix mo sa distilled water, presto...
For modern cars, the EPS seems to be more ubiquitous as the traditional engine-driven PSF...
A/c
