Results 1 to 10 of 20
April 3rd, 2010 04:21 PM #1
mga bossing anu po possible problem pag nababa rpm pag nag switch on k ng headlight?same time nakabukas din ang headlight and on a/c lalo nababa?pag off naman ok naman rpm pag on ang a/c.. possible po b ung alternator?pero nung pinacheck ko ok nman po.stock po alternator ko civic esi 70 amp po.thanks alot..
- Nov 2009
- 456
April 4th, 2010 12:32 AM #2Check mo terminal ng battery kung maluwag. Check din yung fan belt sa alternator kung loose sya. Since its an old car, I suggest magpakabit ng grounding kit para lumakas lahat ng electrical accessories.
April 4th, 2010 01:37 PM #3
eh sir mga how much po ang grounding kit?and may alam k ba pede pakabitan near alabang and how much it will cost?thanks..
- Nov 2009
- 456
April 4th, 2010 02:37 PM #4I'm from QC kaya medyo di ko kabisado Alabang area. Pwede ka tumingin ng grounding kits sa mga car accessory shops like Blade or Concorde (baka meron sa Alabang Town Center). Mga around P1200 if I'm not mistaken. Pwede ipakabit sa kanila or sa suking mekaniko na familiar sa electricals.
April 18th, 2010 01:31 AM #5
sir civicvti nag tanung ako sa mechanic sabi nya grounded lng daw yung line ng headlight.possible ba yun?t.y.
- Nov 2009
- 456
April 18th, 2010 09:42 AM #6
April 18th, 2010 02:56 PM #7
sir civicvti sabi nya kasi pag on lang headlight dun lang daw nababa ang rpm.grounded daw un pero i think tama k
kasi nag search ako dito sa tsikot ng old threads parang same ng prob ko un nga lang sa kanila hirap eh start redundu lang den may nag suggest na grounding kit nga mahina na daw ung ground nung car..panu mag check if grounded ung wiring mo?nag palit pala ako ng battery nung test nila 12.6 amp lng ung nabalik n charge sa battery.t.y.
- Nov 2009
- 456
April 18th, 2010 10:49 PM #8Nakakapag start ka naman ng makina ng maayos so rule out muna natin ang alternator at battery. Yun bang headlight bulbs ay stock wattage? Kasi kung napalitan ng mas mataas, baka dun nagkakaproblema. Otherwise kung stock bulbs, nasa wiring na talaga yan. Since late model na ang inyong Civic ESi, I would suggest na magpakabit na kayo ng grounding kit.
April 24th, 2010 02:08 AM #9
sir civicvti last dec. po nag pa rewire ako ng line ng head ligh mejo punit punit na kasi yung insolator and bakbak n yung electrical tape na naka balot..after 2months nag start na po yung pag baba ng minor.napaltan ko na po yung stock na bulb halugen bulb 100/90w yung pinalit ko.ok naman po yung pag start ko normal naman po..last tuesday night pag on yung headlight nawawala yung busina pag naka stop kailangan ko pa eh rev pero pag off naman meron naman po busina..sir i just want to be sure na grounding kit lang po solution sa problem ko mejo mahal po 2,350php po ngaun sa blade nagtaas daw po sila.hehehe..thanks po sa advise..
- Nov 2009
- 456
April 24th, 2010 09:44 AM #10Nung nagpalit kayo ng wirings sa headlight minodify nyo para maaccomodate yung higher wattage bulbs? If not swerte nyo at hindi natunaw yung wiring at housing. I would suggest na ibalik sa stock wattage kasi nahihirapan yung battery at alternator na magcompensate.
the hybrid corolla cross looks more appealing at those prices.
Mitsubishi Xforce
