Results 1 to 7 of 7
- Nov 2009
- 16
November 28th, 2009 12:57 PM #1[SIZE=3]mga sir.. ung car ko po civic 2000..e ngrerev kht nkaneutral nlng at hnd ko tinatapakan ung gas.. den pagpinump ko n ung gas pedal ngrerev xa ng higher den bagsak n prng mamamatay makina den normal n ult.. or sometimes pg pnpatay ko ung a/c nblik dn xa s normal.. little help mga paps??
THNX IN ADVNCE mga paps..
[/SIZE]
- Apr 2009
- 1,902
November 28th, 2009 03:06 PM #2I had that similar problem before on my d15b.
Pag nakaaircon lang ba siya nagkakaganyan? Pag off a/c normal na ba?
Stock pa ba yung air intake niyan?
You're fuel injectors or maybe the MAP sensor might need some cleaning.
Or pag naka-aircon lang siya nagloloko, you might want to check for worn out alternator and compressor belts.
November 28th, 2009 04:09 PM #3
Check the following need to be clean .Dirty Throttle body, MAF sensor and Idle Air Control Valve causes erratic idling.
- Nov 2009
- 5
November 28th, 2009 04:28 PM #4maybe one of the sensors connected to the throttle body ang may problema.
problema ko din dati yan sa lxi2000 ko. since hindi naman nakakabili ng sensors sa mga surplus, pinalitan ko na lang ng surplus na throttle body. 4k nagastos ko kasama na dun yung labor.
- Nov 2009
- 16
November 29th, 2009 09:03 AM #5kht po boss hnd nkaaircon.. sb ng iba mga paps ung "SERBO" b un dw ang sira?? anu po b un?? hehe den mnsan mga paps ngwiwild mnsan.. up and down rev pro bsta ngpump kna s gas pedal ng once or twice or trice.. ok n ult xa.. nkaracing intake nga po pla ako dun po s ngtnung..
-mga paps tnx s mga rply nyo..
November 29th, 2009 10:36 AM #6
[SIZE="4"]REMINDER: do not post messages in SMS/TXT format
READ the RULES[/SIZE]
November 29th, 2009 12:17 PM #7
Paminsan ganito din yung sakin pag naka-N. akala ko normal lang siya. although yung rev hindi umaabot ng 2krpm. Kadalasan din sumasabay yung pag rev up sa aircon. Ang ginagawa ko na lang binabalik ko sa D or R then balik sa N. City 2006 1.5 car ko. So may prob pag ganito?
Xiaomi E-Car
