Results 1 to 6 of 6
- Aug 2017
- 49
December 22nd, 2017 09:10 AM #1Hi Guys,
Help!!!
My radiator was busted, nagkacrack ung plastic top, sa katagalan nadin siguro. I'm planning to replace it with a brand new one as recommended by others kasi repair will cost a lost (para kang bumili ng bago). May maiirecommend ba kau sakin na radiator? May list na ako dito:
1. Evercool - ok na sana, medyo pricey lang, 1 row brass-copper rad is 6.3k here in laguna direct from the plant
2. Dynamics - 2 rows full alum 7k
3. Top cool - 2 rows plastic top alum radiator 3.8k
4. Hydrocool - 1 row plastic top 2.8k
Pang weekend ride lang car ko, minsan dinadala ng weekdays pag may gala. Plano ko din maglong ride.
Ano kayang radiator ang swak para sakin?
Salamat merry christmas!!!!!!
- Mar 2008
- 54,230
December 22nd, 2017 09:57 AM #2if your outgoing radiator is 1-row, my bukambibig recommendation is the evercool.
because it is brass/copper, it should be fix-able in your friendly radiator shop.
dynamics is aluminum but 2 rows. i think it is also a good choice. namimili lang nga ng repair shop, in the unfortunate event that it needs repair.
plastic radiators are cheap, because... they are cheaper to manufacture.
bottomline. eni op da por will do.
December 22nd, 2017 10:10 AM #3
^ doc so iyong mga oem kaya iyon nilalagay kasi cheaper sila? plastic top kasi iyon di ba?
evercool dati pinagpalit ko sa oem rad ng ek namin and hanggang nabenta ok pa siya
December 22nd, 2017 10:15 AM #4
Yup, that's what it says here...
https://itstillruns.com/honda-civic-...s-6088156.html
"The Honda Civic radiator is constructed with plastic tanks and an aluminum core. The good quality metal radiators are no longer used, in favor of the more lucrative and easily manufactured plastic versions. The center core is simply crimped to the plastic tanks with a gasket between the core and tank. This creates a multitude of possible leaks; however, the most common cause for leaks on the Civic radiator is cracks on the top tank next to the radiator cap. The pressure in the radiator splits the upper tank, resulting in a long crack just above the core. It is a good idea to pressure test the radiator if no obvious cracks are seen."
- Mar 2008
- 54,230
December 22nd, 2017 10:17 AM #5
- Oct 2009
- 2,271
December 23rd, 2017 03:34 PM #6ano ba sira ng dati mo.kung crack lang ung plastic top at ung bottom ,pwede mo namang papalitan ng copper ung itaas at ibaba nun..convertion.
Yung support lang talaga. May vlog si Autorandz nito, nagpa repair ng hybrid battery sa kanila....
China cars
