Results 1 to 7 of 7
    Hi fellow tsikoteer's
    Badly need your advice , I have a big problem with my car's engine. There's a ticking sound whenever the engine is running
    (at least not a tok..tok ). My mechanic also found out oil is spewing from the dipstick.
    He told me engine overhaul is needed to repair the engine.
    Need your inputs on the following
    1. The cost of overhaul is around 40-45k. Which is the best option engine overhaul or engine replacement?
    2. What is the price range of surplus engine?brandnew ?
    3. I'm from Q.C. area (mindanao) any reputable service shops that you can recommend?
    Thanks
    May 2004
    pa compression test po ninyo muna.. baka naman po hindi kailangan overhaul...
    Aug 2004
    Yeah. If the engine isn't clunking, losing tons of oil and severely down on power, overhauling it is probably a waste of money.
    1. Get a compression test.
    2. Have it looked at by someone who knows L-series engines.
    Ah saan kaya pwede mag pa compresion test?
    Aug 2004
    There are quite a few shops that can do it. Just ask around for the one closest to you.
    Just got my car repaired today, buti na lng nag-post ako dito sa forum laki talaga tulong.
    Eto yung mga ginawa
    1. Compression test- Passed 220 passing is 160..
    2 Complete tune-up (spark plugs replaced, throttle AC cleaned pati intake manifold, adjusted valve clearance)
    3. Tsaka nag pa bleed na din ako breaks..additional lng..
    Buti wala ko pera nung sinabi pa-overhaul..hehe. Mas ok na ngaun takbo hindi na namatay makina kahit naka idle.
    Salamat sa lahat.
    Jan 2011
    Quote Originally Posted by tagumpay View Post
    Eto yung mga ginawa
    Salamat sa lahat.
    kahit kailan, di tiningnan ng dealership yung valve clearance? i know all my cars were regularly being checked for the clearance every 20k miles or so.
Replace engine or Overhaul? Honda City 04 iDSI
