Results 1 to 7 of 7
- Jul 2009
- 7
December 12th, 2011 10:58 AM #1Hi fellow tsikoteer's
Badly need your advice , I have a big problem with my car's engine. There's a ticking sound whenever the engine is running
(at least not a tok..tok ). My mechanic also found out oil is spewing from the dipstick.
He told me engine overhaul is needed to repair the engine.
Need your inputs on the following
1. The cost of overhaul is around 40-45k. Which is the best option engine overhaul or engine replacement?
2. What is the price range of surplus engine?brandnew ?
3. I'm from Q.C. area (mindanao) any reputable service shops that you can recommend?
Thanks
- May 2004
- 903
December 12th, 2011 01:16 PM #2pa compression test po ninyo muna.. baka naman po hindi kailangan overhaul...
December 12th, 2011 01:52 PM #3
Yeah. If the engine isn't clunking, losing tons of oil and severely down on power, overhauling it is probably a waste of money.
1. Get a compression test.
2. Have it looked at by someone who knows L-series engines.
- Jul 2009
- 7
December 12th, 2011 05:52 PM #5
There are quite a few shops that can do it. Just ask around for the one closest to you.
- Jul 2009
- 7
December 13th, 2011 10:45 PM #6Just got my car repaired today, buti na lng nag-post ako dito sa forum laki talaga tulong.
Eto yung mga ginawa
1. Compression test- Passed 220 passing is 160..
2 Complete tune-up (spark plugs replaced, throttle AC cleaned pati intake manifold, adjusted valve clearance)
3. Tsaka nag pa bleed na din ako breaks..additional lng..
Buti wala ko pera nung sinabi pa-overhaul..hehe. Mas ok na ngaun takbo hindi na namatay makina kahit naka idle.
Salamat sa lahat.
- Jan 2011
- 317
December 15th, 2011 01:51 PM #7
looks like this version (7th Gen) will be its last After 36 Years, Subaru Is Ending The Legacy...
2020 Subaru Legacy
