Results 1 to 10 of 10
- Apr 2011
- 17
September 4th, 2017 09:27 AM #1Good day, nung inistart ko po yung jazz ko..after mga 10mins umilaw yung overheat indicator...unti unti kong pinasingaw yung sa radiator cap..tinignan ko yung water reservoir pero puno naman..meron akong reserbang mga 2ltrs coolant nilagay ko yun.tapos bumili na ako ng coolant mga 4km balikan nung nag park na ako..tinignan ko yung reservoir ubos na yung coolant. Yung radiator lalagyan ko sana ulit pero puno ng coolant nmn..anu po kya problema nito?tnx..
September 4th, 2017 09:46 AM #2
wala ka bang bang dried up leak stains nakikita around the radiator area and its hoses? iyan kasi ang isa sa mga purpose kung bakit may kulay ang coolant natin at nag-iinidicate ng leak sa mga na mention ko
or may napapansin ka ba na pool of coolant sa ilalim ng sasakyan mo kapag nakaparada ? isa sa mga senyales na ito ng bad water pump
iyong whining sound sa area ng drive belt/s mo pwede din indicator iyon na medyo delikado na water pump bearings niyo
- 54,258
September 4th, 2017 10:11 PM #3you're overheating.
either you have a leak in your radiator, or your aux fans are sub-optimal.
when my (non-honda) car developed worn water pump, it started leaking. it resulted in decreased coolant in the radiator. but my water pump's leak wasn't in the radiator area.
i guess that means, you have to look for that leak.Last edited by dr. d; September 4th, 2017 at 10:15 PM.
September 4th, 2017 10:45 PM #4
Overheat after 10minutes from cold start? It could be a stuck thermostatic valve.
- Apr 2011
- 17
September 5th, 2017 01:48 PM #5Na doble check ko na po lahat wala namang leak..bali ang gnawa ko po ay bleeding saradiator. may na trap talaga na hangin sa radiator bigla po kasing baba yung tubig after mga 2mins naka on ang engine..sana po eto lang talaga..salamat sa reply.
September 5th, 2017 06:07 PM #6
- Apr 2011
- 17
September 7th, 2017 12:19 PM #7Pinaandar ko po..bali ngayun ok nanaman..ang pinoproblema ko lang yung water reserve tank nya beyond na po sa max..tapos pag open ko nung radiator wala pong coolant na laman.pero pag lalamanan ko napupuno agad.bakit kaya ganun.wala naman pong leak? Ilang litres po ba dapat bago mapuno talaga ang radiator? Thanks
September 7th, 2017 05:11 PM #8
How Engine Cooling System Works - YouTube
- Jan 2015
- 468
September 7th, 2017 05:19 PM #9
- Mar 2018
- 50
March 22nd, 2018 08:41 PM #10
That's what he actually did. He also retrofitted an eps to his 1970s era beetle. Btw, now...
A/c
