Results 1 to 3 of 3
- Jun 2009
- 11
October 7th, 2009 07:20 PM #1good day mga tsikoters. tanong ko lang po sana sa mga guru kung ano ang advantages at disadvantages ng paglalagay ng tachomter at racing air flter sa stock engine? or pogi pointslang poba talaga? thanks .
honda lxi 97 stock engine. balak kopo kasi magpalagay. thanks po sa mga magrereply God bless!
October 7th, 2009 07:35 PM #2
Extra (and perhaps expensive) Tach meter for your stock engine is simply a complete waste of money . Bili ka nalang ng other things that you can really use to improve performance.
Racing Air Filter, uh you mean like K&N? Go for the drop-in type instead of the cone type since your stock engine won't suck more air than normal.
The cone type looks good in the engine bay I agree but it does suck in the heat from the engine so you are better off getting cool air from the outside via your stock intake system.
October 7th, 2009 08:51 PM #3
Tachometer is a good addition to the engine if your car doesn't come with one from the factory.
Personally, ok sa akin ang cone type filters. When the car moves, air is sucked in through the grills, air dams, etc, which in turn gives cool air for the filter to suck in. Not necessarily true that all air inside the engine bay is hot.
Also, gains are seen with the proper piping, e.g. tube construction your filter is connected to. That's the x-factor for aftermarket filters.
high idle RPM at engine start
