Originally Posted by
oj88
Depending on the car and situation, you may even save more fuel if you keep it in gear while coasting.
When engine management detects that you took your foot off the gas pedal and you're going at a fast enough speed, the injectors stop feeding fuel into the cylinders, allowing the car's momentum to keep the engine at above idle. Once it goes down to a certain RPM, the injectors fire right back up to keep the engine from stalling. This is done so smoothly and efficiently that you'll probably won't feel the transition. You'll likely need to have a trip computer or digital gauge plugged into the OBDII port to show you how much fuel is being injected at any point in time.
