Results 11 to 20 of 25
July 22nd, 2015 08:04 AM #11
Pa-check mo sa electrical shop like Rey's Electrical. Nasira yung sa driver's side window, ayun binaklas may natanggal lang na wire, solution sinolder lang yung wire. Cost wala pang 400.
- Aug 2015
- 6
- Nov 2012
- 4
August 18th, 2015 12:33 AM #14
I have the same problem with my '01 altis. Since pang coding ko sya, i only use it once a week and nagagamit ko lang na window para buksan yung driver side. I always forget to open and close the other windows para ma activate and di mag stuck. Ayun, all the other windows di na gumagana except the driver's side.
August 18th, 2015 10:35 AM #15
Baka marumi yung contacts ng motor kaya di umoobra yung switch. I have noticed this happens as the car gets older. Kung putol yung cable, di na aangat or tataas yung window. If your power windows start to show some irregularities, have it checked as some mechanics don't charge for assessing the problem. The last thing you want is your window not going back up after opening it to get a ticket when entering an expressway.
August 29th, 2015 10:26 AM #16
Same problem po. Sa power window sa driver side. Huli napalitan ng motor nya ay siguro may 5 years na din pero etong August nag umpisang ayaw gumana minsan. Sinubukan ko kanina buksan at hinawakan ko motor nya ay mainit. Nasa 1,000 plus yata yun mga 2nd hand na motor. 1996 model honda civic vti ko.
August 30th, 2015 11:45 PM #17
August 31st, 2015 01:30 AM #18
Baliktad tayo. Sa akin drive'rs side naman ang nagloloko. One time kumuha ako ng parking card medyo nasobrahan yata pagkababa ng window ayaw na umakyat. Ang tagal bago ko nai-close yung window. Di ko naman pwede iwanan na nakabukas lang kahit pa covered parking.
Baliktad tayo. Sa akin driver's side naman ang nagloloko, Altis din pero '03 naman. One time kumuha ako ng parking card medyo nasobrahan yata pagkababa ng window ayaw na umakyat ulit. Ang tagal bago ko nai-close yung window. Di ko naman pwede iwanan na nakabukas lang kahit pa covered parking.
- Dec 2013
- 16
September 1st, 2015 06:18 PM #19What model and year? Madali lang magtroubleshoot ng electricals ng power window. I'll send you the wiring diagram. All you need is a multimeter and some DIY attitude.
- Jan 2018
- 10
April 2nd, 2018 11:38 PM #20May nakapagtry na po ba sa inyo ng universal power window conversion kit? Kumusta po performance? Tia[emoji846]
Apparently, that's turning out to be a rather small crowd.
