Results 1 to 6 of 6
- Jun 2010
- 258
June 28th, 2010 06:52 AM #1before di nman to ganito, usually one click lang yun starting nito pag pasok mo ng key tas twist start na agad...
but now pag start ko.. parang pumupugak at di tumutuloy sa starting..kelangan ko pa bombahin ang gas para tumuloy siya mag start.. pls help mga sir... newbie on cars lang po. salamat ng marami
- Jun 2010
- 258
June 29th, 2010 09:26 AM #3
Have you tried getting the engine's throttle body cleaned?
When was your last tune up?
Replaced the sparkplugs recently? (correct gapping?)
Are the high tension cables in good condition (no cracks)?
June 29th, 2010 09:46 AM #4
pwedeng starter ang problema or a weak battery na. try to check isa isa para malaman mo yung pinaka cause
- Jun 2010
- 258
June 30th, 2010 04:58 AM #6thanks sa reply mga sir... last tuned up was march, battery was changed september... dont know if how old na mga spark plugs,, oansin ko lang yun high tension wire may konti parang ngatngat ng daga.. would that affect the starting?
i used to have android auto disconnection issues until i tried this. usb 3.0 to type-c adapter, and...
Suzuki JIMNY [merged threads]
